Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 09-30-2016, 09:38 PM   #141
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
So some other folks should have this kit installed by now. So anyone want to share their experiences with the install and performance?
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-01-2016, 09:17 AM   #142
BAD DAB
BAD DAB's Avatar
Is this kit available in audio retail stores yet?
Old 10-01-2016, 10:52 AM   #143
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
It drives me crazy that people will produce such a nice looking kit, but make a bad decision - in this case, on a couple of cheap switches - that make the whole kit less appealing.
If they came up with better switches (just going off what other people have said), I'd order one of these right away.
Yippee38
Yippee38 is offline   Reply With Quote
Old 10-01-2016, 11:43 AM   #144
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Email them or call them with your concerns. If enough people contact them about some design or hardware issues, they may make some changes. But if no one says anything, then they definitely won't.
I really want to get this kit, but it won't work with the 2DIN radios I want to use. It seems like they designed the radio opening to accommodate with big name brands, but they failed to realize more and more people are going with different units. And these units are slightly wider and taller. I have an Android radio in my Suburban and I really don't want to go back to Pioneer, Kenwood, Alpine, etc.
Low Saturn is offline   Reply With Quote
Old 10-01-2016, 12:32 PM   #145
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
Elaborate. Car Toys etc? If they refuse to source and install it then they are morons, find a different shop,
Snoman is offline   Reply With Quote
Old 10-01-2016, 12:34 PM   #146
Snoman
H-Town Camaro Club
Snoman's Avatar
Old 10-01-2016, 01:38 PM   #147
patternpilot
Drives: 2012 2SS/RS
I have to admit that the switches do not work as I would like. The door lock switches on my unit work fine and make contact with very little effort or pressure. But I use the door lock switches on the door so it doesn't matter to me and could have been left out entirely. Now the hazard switch is hard to make contact. I have to press it several times to get them to work. They do work though and you hopefully wont need them very often. Improvement could take place. Minor to me but maybe not to others.
Old 10-01-2016, 06:09 PM   #148
kain929
kain929's Avatar
Drives: 2012 2SS, Silver, Borla S Type, CAI
I just ordered on of these kits from phasetek today. Hopefully it works without flaws.
kain929 is offline   Reply With Quote
Old 10-01-2016, 06:29 PM   #149
kain929
kain929's Avatar
I ordered the Pioneer AVH-X5800BHS head unit. Holding it up to the PAC unit it has a perfect fit. It also has a tilting adjustment to tilt the faceplate for easier access. I have not had time to install yet but hope to start tomorrow.
Can you post pics of the finished project? I purchased the Pioneer AVH-X4800BS. I'm sure the head units are the same size. The kit is on order from Phasetek and should be in soon.
Old 10-01-2016, 06:36 PM   #150
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
So the factory reverse camara works ...
RLNTLSS is offline   Reply With Quote
Old 10-01-2016, 10:12 PM   #151
patternpilot
Drives: 2012 2SS/RS
My reverse camera is in the mirror and still works fine. I think if you have the My Link it will still work.
Old 10-01-2016, 10:16 PM   #152
patternpilot
Drives: 2012 2SS/RS
Post 67
Old 10-02-2016, 07:45 AM   #153
rydahog
rydahog's Avatar
Drives: camaro ss
reverse camera new headunit
i have the reverse camera in my mirror and i got the gen5diy adapter that moves it to headunit from mirror. plug n play...or he also has one that both HU/mirror can still be used.
rydahog is offline   Reply With Quote
Old 10-02-2016, 09:08 AM   #154
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Where does one order this kit with all the rite parts already gathered. The chime that seems to be missimg from the kit.does it come with radio harness for aftermarket radio.. or do i need to source one out ... metra aftermarket wiring accessory?
