11-02-2022, 12:07 PM | #15 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
Same boat man. No idea where to start.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
11-02-2022, 12:14 PM | #16 |
Here is my amateur understanding of the functionality these two parts provide.
The thermostat governs the opening and closing of the valve that enables coolant flow. When it works, it opens and closes regularly to keep coolant/engine temperatures stable and in the optimal range. When it gets stuck open, the engine is always cooled and takes much longer to heat up; when it gets stuck closed, the engine can overheat because coolant isn't flowing. Either way, coolant/engine temperature should display correctly. The temperature sensor is usually very close to or part of the thermostat and sends a temperature signal to the BCM that then displays it in the cluster. When it fails, the display is stuck at a single temperature, usually 0. This does not necessarily mean the thermostat is broken, just that you have no indication of actual temperatures. EDIT: this is what I found in the service manual about thermostat housing replacement for the V6 engine (LGX), not sure if it's enough for you guys, but hopefully it's a start.
11-02-2022, 01:01 PM | #17 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
The constantly running fan is a failsafe feature that the ECU will engage when it detects something wrong. You might also notice that your oil pressure is higher than normal as well.
arpad pretty much covered everything. I would say that you could just idle the car for more than 10 minutes, open the hood and feel if the block and the upper radiator hose are lukewarm, but now that the weather is cold, I am not sure if this works well. If they are still pretty much cold after idling for a while then yeah, you have a stuck open thermostat. I once helped a friend flush his NA Miata's coolant and found that the block would be pretty hot but the radiator is still stone cold and this is after idling for 10+ minutes on a summer day. Turns out the thermostat is stuck closed. Ended up helping him replace the thermostat. If it's failing to pick up anything then yes, that's the coolant temperature sensor. Get an OBD2 reader and you should know what's going on.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
11-02-2022, 02:50 PM | #18 |
Well either way thankfully im better off, or at least will have an easier time, than the OP simply because I have the V8.
11-02-2022, 04:30 PM | #19 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
11-02-2022, 05:00 PM | #20 |
Only thing that would make it easier would be not needing to empty coolant first.
11-02-2022, 05:25 PM | #21 |
Drives: 2016 chevy camaro Join Date: Dec 2021
Ok I bought a ODM2 meter and it says I need to replace the thermostat. What kind of tools will I need to get this job done and realistically how long should this take? Would you guys recommend me buying the part and then paying a mechanic to do the work? The biggest car project I've ever done is replacing bad brake pads and this was 15 years ago.
11-02-2022, 08:23 PM | #22 | |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
11-02-2022, 10:20 PM | #23 |
Drives: 2016 SS Join Date: Jan 2016
11-02-2022, 10:23 PM | #24 |
you are wasting your time and money, it is your thermostat. Period. i replaced too many to know. do the sensor if that make you happy but you will find out that wont fix your problem.
11-02-2022, 11:28 PM | #25 |
Monterey County Camaros
For what it's worth..
Follow us on Instagram @montereycountycamaros
11-03-2022, 10:48 AM | #26 |
11-03-2022, 02:02 PM | #27 |
Drives: 2022 Camaro 2SS A10 Coupe Join Date: Sep 2022
11-04-2022, 05:21 PM | #28 |
Ever since the last time I disconnected the battery the car will tell me which seat memory setting I am using on the dic at startup. It never used to before.
