Old 01-27-2016, 01:21 PM   #1
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
ENGINE TEMPS AFTER OIL COOLER DELETE QUESTION?
I have a 2010 2SS/RS with only 12000 mi. on the clock that has a small oil leak where the oil cooler casting bolts to the block. I have tightened the two mounting bolts a little tighter, but the leak is still there. The car is out of the factory warranty so it is up to me to fix it or just put up with it.
I did confirm that it is leaking from the gasket & not the freeze plug in the end of the casting & that would be an easy fix just replacing the gasket, but I am now thinking of just removing the cooler & the coolant lines to it eliminating any future leaks.
My question is, after you removed the factory oil cooler are the engine oil temps staying close to where they need to be in the 210- 220 degree range for a daily driven car? Also, what tool did you use to remove the threaded fitting in the side of the block that you need to plug that is used for the coolant supply to the cooler?
Thanks SO MUCH in advance for your help.
All The Best
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 01-27-2016, 01:28 PM   #2
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
I removed mine about a month ago and my oil temps are exactly the same (just above 200 deg). I used some pliers to get the fitting out of the block. It was a little difficult to remove due to the tight space. I did a little write up on it a few weeks ago. I would say go for. I removed mine due to coolant leak at the said fitting you are referring too.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 01-27-2016, 02:24 PM   #3
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
Link to his write up: http://www.camaro5.com/forums/showthread.php?t=434875
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 01-27-2016, 03:34 PM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Does the oil heat up as quickly as it did before removing that cooler?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-27-2016, 05:31 PM   #5
TXM62SS
TXM62SS's Avatar
Unfortunately it does not for me. I was hoping it would but no such luck.
3.91 1LE Gears, MGW
Tuned by Pat G
Old 01-27-2016, 05:43 PM   #6
xc_SS/RS
Thanks for the answer. Might not do this then unless mine starts to leak
2010 2SS/RS
Old 01-27-2016, 07:53 PM   #7
mar10
mar10's Avatar
Drives: 2010 SS RS
I'm pretty sure that the oil temp gauge is not accurate. It is basically an estimate done by the computer based on rpms and speed not an actual temp reading. The temp displayed is estimated based on the stock system. So removing the oil cooler or adding an aftermarket one probably won't change what the factory gauge reads.
Stainless Power Longtube headers, off road mids, stock H pipe, flowmaster mufflers, Vararam tune model intake, NightFury cam, and 91 octane email tune from Dynosteve @ rdpmotorsport.com. 473 rwhp and 430 ft. Lbs. @3,235 ft elevation.
mar10 is offline   Reply With Quote
Old 01-29-2016, 08:42 AM   #8
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I thought that was true too. After a bit of research, the oil temp is integrated with the Oil level sensor. I have not got a firm answer from a true Camaro guru if this is true or not.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 01-29-2016, 09:21 AM   #9
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
The factory piece is actually more of an oil heater than a cooler. Mine has been off for a year now.
The factory piece is designed to heat the oil up quickly for emissions purposes.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 01-29-2016, 09:47 AM   #10
xc_SS/RS
I would be interested in seeing a comparison to the stock gauge with an aftermarket gauge or a scan gauge.
If it is a calculated amount based on engine rpm and the cars speed then wouldn't deleting the stock cooler/warmer not cause a difference in the reading of the stock gauge?
2010 2SS/RS
Old 01-29-2016, 10:23 AM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Other cars don't even have factory oil coolers, the G8 for example.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 01-29-2016, 10:29 AM   #12
Unreal
Drives: 2006 Z06
Or most corvettes.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 01-29-2016, 10:44 AM   #13
xc_SS/RS
Originally Posted by Unreal View Post
Or most corvettes.
So I guess technically it isn't even necessary for our cars is it? A good external cooler is good for those who run road courses but for daily drivers or those who do a few track days the stock cooler isn't necessary?
2010 2SS/RS
Old 01-29-2016, 12:12 PM   #14
Orange 2010 Camaro
A BIG Thanks to ALL of you who have helped me with the comments & information regarding the oil cooler delete. Looks like mine is going to end up in a box in my garage.
It will also clean up some of the clutter on the drivers side of the engine!
All The Best,
Orange 2010 Camaro
