01-16-2013, 11:15 PM | #1 |
Drives: 2010 Camaro 1ss/rs Join Date: Mar 2009
STROKER...
Im looking to make my motor a complete forged stroker. i have a cam, lifter, rods and full exhaust. i know going to a 416 is pretty safe. How much on average to have a shop AKA lingenfelter build my motor for me, and what kinds of gains have you guys seen with a NA forged stroker LS3?
01-16-2013, 11:38 PM | #2 | |
Drives: G5.R Join Date: Sep 2010
01-16-2013, 11:47 PM | #3 |
What are the benefits of a short block vs long block. As far as accesories, i plan on droping off my car having them do 100% of the work and going back to pick the car up once its completed
01-17-2013, 12:06 AM | #4 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
01-17-2013, 05:30 AM | #5 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Ive seen 416 short blocks go for less than $5000.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
01-17-2013, 05:48 AM | #6 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Forged 416's are usually for F.I. If you plan on staying N/A I would build something that is 427+ci. A crate motor works for what you want.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
01-17-2013, 07:43 AM | #7 |
01-17-2013, 08:11 AM | #8 |
I have plans on a 416-418 when its time and I will be N/A.
01-17-2013, 09:28 AM | #9 | |
Reason I ask is because if the cam is a grind optimized to work with the stock stroke, you're going to need a cam with more duration usually to have the same operating range. If you dont, You are essentially wasting the extra "effective stroke" you would have available to you with the proper cam as well. The shelf cam for the 376 used in a 416 is going to have a lower torque and power peak than the 376 had, and depending on if your stroker assembly piston has yields compression or not, you may also find that the cam with the smaller duration is going to have more cylinder pressure than you may want. In some cases this can limit the total spark advance you can use, and/or raise the octane requirement making fuel more expensive. Just saying. |
01-17-2013, 10:43 AM | #10 | ||
Drives: Camaro Join Date: Apr 2009
Give us a call & we can discuss options. We have every combo you can imagine! Here's a link to another thread discussing strokers:
http://www.camaro5.com/forums/showthread.php?t=271438 Here's a link to our machine shop & some video of us digitizing a block before cnc machining. Digitizing video: Here's a link to our machine shop. It currently includes 8 cnc machines. http://www.texas-speed.com/t-Enginebuildinfo.aspx Here's a example of a PRC LS7 head getting cnc roughed. |
01-17-2013, 10:47 AM | #11 |
Says me.There is no replacement for displacement. Couple bucks more gets you more Cubic inches (NA power=ci) seems pretty simple to me
01-17-2013, 11:09 AM | #12 | |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
This is so dead wrong. Stroke is pure mechanic advantage (longer lever) and the best thing you can do to make torque and power. There is no way EVER that the same engine with more stroke does not lose power. In fact it makes nearly lineal power gains (20% more stroke = 20% more torque). I've also got the stats to prove it. My race car went from a 302, to a 350 to a 383. Same bore, heads, cam, everything but crank and rods. Kept stroking it out. 302 ran 11.80, 350 ran 11.10 and the 383 ran 10.60. Geez man, where do people get this mis-information?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
01-17-2013, 11:20 AM | #13 |
Depends on how you get the bore size. Either buy a ls7 block or a sleeved block. How much power difference are you going to get out of 10 cubic inches vs how much it costs to get those 10. I too believe in displacement but its not like going from a 383 to a 408.
01-17-2013, 11:57 AM | #14 |
That why I suggested he go 427 c.i plus. It's about 1.5 HP per cubic inch. So 376 to a 427 is 17 Hp over 376 to 416. Building a beast of a N/A motor is not a cheap proposition. Slap a 440 in the thing and be done.
