07-01-2019, 09:38 AM | #1 |
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp Join Date: Jun 2019
Does P3 gauge do boost?
Looking at the P3 Gauge that goes in ac vent, question does anybody know if this gauge reads boost off the ODP port or do you have to run tubing also?
07-01-2019, 10:00 AM | #2 |
Drives: SEARCHING Join Date: Apr 2010
07-01-2019, 12:18 PM | #3 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
No. You can't accurately read boost from the OBD2 with any gauge for these cars. You have to run a vacuum line from the 1/8" NPT port on a throttle body spacer from ZZP or BNR.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
07-01-2019, 12:30 PM | #4 |
Correct. It will read what's reported on the ECU. Using a boost tap is always the best method.
07-03-2019, 07:11 AM | #5 |
I thought it was to easy. I am just looking to see what the boost is doing surprised Chevy doesn't have a boost gauge.
07-03-2019, 08:08 AM | #6 |
