05-07-2015, 11:56 PM | #1 |
drag strip
Well today was my first time at the strip with a best time of 12.903 in the 1/4mile
But my question is, is there something to control my launch with an automatic that i can leave the line at like 3 or 4 thousand rpms? |
05-08-2015, 07:06 AM | #2 |
Thread Ender
Drives: 2010 Camaro 2SS/RS L99 Join Date: May 2011
An aftermarket torque converter with a higher stall?
05-08-2015, 08:01 AM | #3 |
Drives: 2011 Camaro 2SS/RS L99 Join Date: Aug 2013
IV been told to put the car in competition mode, then hit the brake and gas simultaneously until your at like 2000rpm, then release brake and slam gas when you see that last yellow light
Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance |
05-08-2015, 08:54 AM | #4 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Better have some good drag radials for that. My V6 will spin launching at 1400 RPM with summer tires.
05-08-2015, 09:11 AM | #5 |
My tires started to spin st like 1500rpm off the line
05-08-2015, 09:18 AM | #6 |
Drag radials and torque converter are in your future then. Will shave a lot of time off. Just make sure you have a good tuner for it.
05-08-2015, 09:23 AM | #7 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
I have a ls3 1LE and I can't get my tires to spin they just GRAB.
05-08-2015, 12:08 PM | #8 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
A higher stall converter is fairly useless if your spinning off the line.
Autos have lower first and torque converter acts as torque multiplier as well. With the m6 you have to learn how to slip the clutch so you can keep the RPMs up. I'm working on that myself right now.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
