05-28-2021, 07:48 PM | #15 |
Smart That should provide a good seal.
10-16-2021, 05:20 AM | #16 |
How have they been holding up?
10-16-2021, 12:16 PM | #17 |
Drives: 2010 2SS & 2013 ZL1 Vert Join Date: Mar 2015
These lights are pretty legit. I think ima do this. Good info here.
10-16-2021, 10:19 PM | #18 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2015
LED bulbs
My initial silicone wrap kind of loosened one connection, just had to re-wrap it. The bulbs have been fine.
I don't want to belong to any club that would have me as a member. - G. Marx |
10-17-2021, 06:16 AM | #19 |
10-17-2021, 08:12 PM | #20 |
Looks like it. https://www.amazon.com/gp/product/B0...&tag=wdls01-20
10-18-2021, 06:54 AM | #21 | |
I thought they were standalone LEDs with separate harnesses with 2 resistors per harness How is their brightness compared to stock? Is the light dispersed evenly thru the lense as LEDs tend to project brightest straight ahead compared to the spherical evenness projection of incandescent bulbs? Is there a significant difference in brightness between the tail light and brake light? Thanks again. Much appreciated! |
10-18-2021, 11:19 PM | #22 | |
I only know the brake lights are brighter by how much brighter they reflect off the garage door.
10-19-2021, 08:14 AM | #23 | |
FWIW ...check out post#59 in this thread for another (cheap & EZ) LED lighting mod you might want to consider https://www.camaro5.com/forums/showt...9#post11079479 |
10-19-2021, 09:43 AM | #24 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Never thought about LED in the brake lights... is this a thing now here on Camaro5?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-24-2021, 02:07 PM | #25 |
Drives: C5 LS3, C5 LS1, ZL1 LSA Join Date: Feb 2018
Yes, because the Afterburners are poopie, and nobody wants to spend $400 on poopie. These are $30 a side and warranty.
02-02-2024, 07:25 PM | #26 |
02-03-2024, 02:43 PM | #27 |
mostly fine
I had one of the filimets on one the connectors rust and break off. I suspect the dialectric grease and\or something else got on it.
I bought another pair so have a spare. That was a couple years ago, no issues since. Not blaming the product for that.
02-04-2024, 12:57 PM | #28 |
Hey, Really glad to get your reply as I didn’t know if you were still on the forum, and also especially glad to hear your 2nd set have held up. Maybe some moisture got in the first set before you applied the dialectric grease?
Did you apply dialectric grease on the 2nd set before or after you plugged the contact fitting in and did use silicone tape again? Thanks |
