03-23-2017, 02:36 PM | #1 |
Drives: 2017 camaro ss Join Date: Mar 2017
Active rev match issue
I've searched the forums and called some corvette owners that I know with the same active rev match system that we have in our cars and I haven't heard of anyone so far having this issue. When I up shift with ARM on when I push the clutch in it almost acts as the break.. it pushes me forward in my seat and stops my car from accelerating for a split second before I'm into the next gear and off the clutch. Has anyone experienced this? Any thoughts on what this could be? It only happens when accelerating faster than normal. No issues under normal driving conditions.
03-28-2017, 09:35 PM | #2 |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
Maybe a worn clutch thats slipping when you push it hard? It's hard to tell from your description but this sounds like something you should take to the dealer and have them check if you're still under warranty.
03-28-2017, 10:21 PM | #3 | |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
03-28-2017, 10:25 PM | #4 | |
ummmm
03-29-2017, 07:45 AM | #5 | |
Drives: 2016 SS Hyper Blue Join Date: Jan 2016
10-21-2017, 06:12 PM | #6 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
My car does the same exact thing. Only when ARM is on. When it's off it behaves like normal.
10-22-2017, 05:42 AM | #7 | |
09-04-2018, 02:20 AM | #8 |
Drives: 2000 Trans Am M6 Join Date: Mar 2018
I have noticed the exact same thing with my car too and I assumed I needed to learn to drive this car a little differently. I always have the ARM on so I'm going to see if it does this with it off too. I learned that it won't jerk during an upshift under heavy acceleration if I lift off the throttle BEFORE I push the clutch in. I mean don't even touch the clutch pedal before you've lifted off the throttle. The clutch pedal apparently has sensors/switches that can detect even an 1/8" or so of travel. I know it sounds totally counterintuitive, but it makes the shifts so much smoother. The reason is that the DBW throttle is still open for a moment after you've lifted off the accelerator pedal. Of course, this doesn't let you bang through the gears like a pro racer, but for that there's the no lift shift feature.
2018 - 1SS - 1LE - Red Hot
09-04-2018, 08:14 AM | #9 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I'm not having this issue that I can tell with active rev match. Could you guys be resting your foot on the clutch prior to executing the shift and that's wreaking havoc on the rev match algorithm? Just a thought.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
