02-01-2018, 10:51 AM | #1 | ||||||||||||||||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
New Track: Bone Stock 1/4 mile ET 11.17 sec?
Here's the time slip for pass #4:
Yeah, you're probably thinking the same thing I was... WTF! I suppose someone dishonest could try to post this on the fast list - not me. Pass #4 felt pretty good but not spectacular - I figured maybe 11.7. The time slip showed a record time of 11.17! My heart jumped! Could this be true - nearly a half-sec faster than my record 11.63?! Looking more closely at the time slip it was obvious there was some kind of malfunction in the timers or time-slip system. It showed 118 MPH at 1/8 mile and 74 MPH at 1/4 mile. After reviewing the videos later on it was obviously a malfunction. [Time Slips] This was my first visit to Fayetteville Motorsports Park. Their time slips are a lot different than Coastal Plains Dragway where I normally go. First there are no car numbers, only a 5-digit alphanumeric abbreviation that the tower apparently adds when you line up. Their timing system is obviously outdated because the date stamp is from 1/1/2009 and 2 hrs earlier than actual. I had to add-in the corrected date/time to sort and correlate them. The time slips are inconsistent whether a red-light is even recorded and red-light reaction time looks the same as normal. I'm used to seeing a negative RT on Red-lt. Pass #2 had a very odd record of the left lane too, showing only reaction time with a ridiculous number of more then 32 secs - no other data. Car Setup: Stock rubber (cold) 21 PSI rear 36 PSI front 93 octane E10 pump gas - 1st pass with 5/8 tank (approx 10 gal) [Summary] Friends have told me how great this track was for them - well prepped, fast, good people... so I arrived full of hope. Since the forecast called for temps in the low 50s there was a good chance I could break my bone-stock record ET. Right away I could tell the temps were going to soar into the 60s. My first pass was 11.7 even with a few slip-ups so I was anxious to do something before it warmed too much. This track was oriented NE to SW, opposite of my normal track. This puts the sun right in my eyes and glare on the windshield, blocking my HUD. My 2nd and 3rd passes I kept waiting too long to shift which landed me in 11.9 territory. It ended up being about 10 degrees warmer than forecast. It wasn't too crowded so I managed to get 8 passes with 2 cool-downs before they closed up. My last 2 passes were basically wasted because I didn't consider the rapid track cooling due to shading - should have added 4 gal fuel for weight/traction. On my last pass the car in front must have leaked fluids all over the 60ft. I broke traction and went sideways mid-1st gear. Didn't bother finishing that pass - just motored back to the paddock. Overall, it's a well prepared, well-organized track with friendly staff but the timers and time slip issues are very frustrating. I don't think it's worth traveling over 3 hours and putting all those miles on the car. With the additional negative factors (1) prevailing winds are SW to NE [headwinds], and (2) afternoon sun shines in the windshield blocking the HUD; I doubt I'll be back. Maybe if they update their sensors/timers. Below are all the details for each pass, including links to spectator videos and combined PDR/Helmet/Roof video. I got distracted trying to get used to the new track so some Helmet and Roof-mounted footage is missing. As always, I welcome constructive criticism and helpful comments. This YouTube playlist contains all the passes: 20180121 First visit to Fayetteville Dragway Let 'er rip! --Cal Time Slip Data: (My 6th Gen ZL1 was always right-lane) Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6363 13:17:31 0.6088 2.0362 11.7154 123.86 Solo 6369 13:24:59 0.4550 2.1909 11.9729 122.32 LittleBlackCar 32.8454 none none none RedLt 6372 13:28:10 0.3485 2.1941 11.9783 122.22 Solo 6449 14:44:22 0.5286 1.7052 11.1702 73.82 BlackBMW 0.5499 1.3605 12.0617 66.39 6467 14:57:52 0.6012 1.9852 12.0821 120.39 WhiteCorvetteVert 0.9262 2.0746 13.9533 109.52 RedLt 6479 15:07:40 0.4869 2.1677 12.0189 121.42 WhiteNissanZ 0.9020 2.2889 13.8457 102.20 6549 16:49:14 0.7485 2.1395 11.9787 121.89 SilverTurbo 1.0023 1.7473 10.8852 129.87 6569 17:07:14 0.5830 2.2191 20.4194 53.98 RedSuperBee 0.8537 1.7293 11.5915 117.31 1. Idle near 3900 RPM so wheels spin slightly on launch. Bogging can cost 2-5 10ths 2. Get out of throttle as soon as clutch goes in - if you can't see the HUD, go by sound 3. Speed shift better/faster - you can pick up a few 10ths there alone Time Slips 1-4 Time Slips 5-8 ============================================= 20180121 FMP Pass 01 of 08 6th Gen ZL1 Solo 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 68°F, wind SW 4 mph, 39% humidity, barometer 30.20 in, DA 509 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6363 13:17:31 0.6088 2.0362 11.7154 123.86 Solo Stock Rubber Right Lane 10-sec Line-Lock burnout Idle @ 3800 RPM Launch @ 3800 RPM Slight wheel slip 3100-3600 Dropped to 1500 RPM Hooked @ 1500 RPM - slight bog Shift 2nd @ 6300 RPM Shift 3rd @ 6600 RPM - slow shift Shift 4th @ 6600 RPM Finish @ 5900 RPM, 128 MPH Spectator Video: PDR Video: ============================================= ============================================= 20180121 FMP Pass 02 of 08 6th Gen ZL1 vs Little Black Car 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 68°F, wind SW 4 mph, 39% humidity, barometer 30.20 in, DA 509 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6369 13:24:59 0.4550 2.1909 11.9729 122.32 LittleBlackCar 32.8454 none none none RedLt Stock Rubber Right Lane Rolling burnout - past start gate, repositioned Idle @ 3100 RPM Launch @ 3900 RPM - Bogged Red-light Dropped to hook @ 1300 RPM Shift 2nd @ 6500 RPM Shift 3rd @ 6600 RPM - slow shift - hit rev lim Shift 4th @ 6600 RPM Finish @ 5700 RPM, 127 MPH Time slip just says "Red Lt", no neg RT. Spectator Video: PDR Video: ============================================= ============================================= 20180121 FMP Pass 03 of 08 6th Gen ZL1 Solo 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 68°F, wind SW 4 mph, 39% humidity, barometer 30.20 in, DA 509 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6372 13:28:10 0.3485 2.1941 11.9783 122.22 Solo Stock Rubber Right Lane Rolling burnout Idle @ 2800 RPM Launch @ 3500 RPM - Bogged badly Dropped to 600 RPM Shift 2nd @ 6600 RPM - slow shift, lingering throttle Shift 3rd @ 6600 RPM - slow shift Shift 4th @ 6600 RPM Finish @ 6000 RPM, 129 MPH Time sheet does not show red-lt but it clearly came on Idle near 3900 RPM so wheels spin slightly on launch. Lost 2-3 10ths on the bogging. Need to get out of throttle as soon as clutch goes in Speed shift better - lost at least 2 10ths on slow shifting Spectator Video: PDR Video: ============================================= ============================================= 20180121 FMP Pass 04 of 08 6th Gen ZL1 vs Black BMW 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 70°F, wind SSW 5 mph, 38% humidity, barometer 30.17 in, DA 677 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6449 14:44:22 0.5286 1.7052 11.1702 73.82 BlackBMW 0.5499 1.3605 12.0617 66.39 Stock Rubber Right Lane Rolling burnout Idle @ 3600 RPM Launch @ 3600 RPM Slight wheel slip 3600-2800-4500-3100 Hooked @ 2800 RPM, 27 MPH Shift 2nd @ 6600 RPM - slow shift - lingered on throttle @ redline Shift 3rd @ 6600 RPM - slow shift Shift 4th @ 6600 RPM Finish @ 5800 RPM, 126 MPH Launch felt fantastic - should have been best 60 ft ever ** Record Time 11.17 ** (has to be faulty time slip) Scoreboard says 12.27 @ 121.52 MPH Time slip says 11.1702 @ 73.82 MPH w/ 1.7052 60 FT PDR says 12.10 @ 126 (the more wheel spin, less reliable) ##!! Burnout shows good example of uneven eLSD torque distribution Left tire always wears much faster than right Can this be adjusted? Spectator Video: Combined In-On Car Video: ============================================= ============================================= 20180121 FMP Pass 05 of 08 6th Gen ZL1 vs White Corvette Convertible 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 70°F, wind SSW 5 mph, 38% humidity, barometer 30.17 in, DA 677 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6467 14:57:52 0.6012 1.9852 12.0821 120.39 WhiteCorvetteVert 0.9262 2.0746 13.9533 109.52 RedLt Stock Rubber Right Lane Rolling burnout Idle @ 3300 RPM Launch @ 3800 RPM - Bogged Slight wheel slip 3800-1800 Hooked @ 1900 RPM, 19 MPH Missed shift 2nd @ 6600 RPM Shift 3rd @ 6600 RPM - slow shift - lingering throttle Shift 4th @ 6500 RPM Finish @ 5800 RPM, 124 MPH Shift like you mean it!!! All the way out of the throttle on shifts Listen for engine tone @ 6600 RPM and/or watch HUD Spectator Video: Combined In-On Car Video: ============================================= ============================================= 20180121 FMP Pass 06 of 08 6th Gen ZL1 vs White Nissan Z 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 70°F, wind SSW 5 mph, 38% humidity, barometer 30.17 in, DA 677 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6479 15:07:40 0.4869 2.1677 12.0189 121.42 WhiteNissanZ 0.9020 2.2889 13.8457 102.20 Stock Rubber Right Lane Rolling burnout - past start gate, repositioned passed stage 1 gate (light went out) Idle @ 2500 RPM Launch @ 3500 RPM - Bogged Red-light Slight wheel slip 3600-1400 Hooked @ 1400 RPM, 14 MPH Shift 2nd @ 6200 RPM Shift 3rd @ 6600 RPM Shift 4th @ 6500 RPM Finish @ 5800 RPM, 125 MPH Watch your timing at the light! Throttle-in/clutch-out 1/4 sec after 3rd yellow. Speed-shift @ redline for every gear! Spectator Video: Combined In-On Car Video: ============================================= ============================================= 20180121 FMP Pass 07 of 08 6th Gen ZL1 vs Silver Turbo 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 68°F, wind S 3 mph, 40% humidity, barometer 30.17 in, DA 546 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6549 16:49:14 0.7485 2.1395 11.9787 121.89 SilverTurbo 1.0023 1.7473 10.8852 129.87 Stock Rubber Right Lane Burnout area, start line completely shaded 8-sec Line-Lock burnout Idle @ 2600 RPM Launch @ 3600 RPM Slight wheel slip 3600-1700 Hooked @ 1700 RPM, 17 MPH Momentary wheel slip @ 5400 RPM Shift 2nd @ 6300 RPM Shift 3rd @ 6600 RPM Shift 4th @ 6600 RPM Finish @ 5800 RPM, 126 MPH Remember to idle and launch @ 3900 RPM! Should have added 4-5 gal fuel for weight/traction on cold track. Don't let noise of other car distract. Watch HUD if can't hear motor to shift @ redline. ## By this time of day, everything behind the start gate is in shade also most of the run-out area after the scoreboards ## Opposing driver asked to line up with me. Such a little car - figured he has nitro and/or turbos. Says he's done nothing to his car. Yeah, right! Spectator Video: Combined In-On Car Video: ============================================= ============================================= 20180121 FMP Pass 08 of 08 6th Gen ZL1 vs Orange Super Bee 20180121 Fayetteville Motorsports Park Weather: Ptly cloudy, 68°F, wind S 3 mph, 40% humidity, barometer 30.17 in, DA 546 ft Time Slip Data: Code:
2017 6th Gen Camaro ZL1 Opposing Lane Seq Time R/T 60 ft ET MPH Opposing Car R/T 60 ft ET MPH 6569 17:07:14 0.5830 2.2191 20.4194 53.98 RedSuperBee 0.8537 1.7293 11.5915 117.31 Stock Rubber Right Lane Rolling burnout Passed start gate, repositioned Overran stage 1 gate (light out) No idle - rushed launch Never stopped slipping... forfeited pass Over-ran staging gate again, repositioned Hit oil/fluid on track - Started getting sideways, then got out of the groove 2nd attempt to throttle up went sideways too, fluid still on tires Just gave up the run and drove through ##!! Entire burnout, launch, and first 60 ft all shaded (cold) When air/track cools late in day: Too light on fuel - should have been btwn 1/2-3/4 tank Should have done another line-lock burnout Spectator Video: Combined In-On Car Video: ============================================= |
02-01-2018, 11:24 AM | #2 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I'm planning on a visit to Rockingham on Saturday the 17th to finally get some runs in after 14,000 miles of driving. I'm just tired of FMP, I wish the Rock did TNT more often. Is that too far for you to go?
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
02-01-2018, 05:05 PM | #3 | |
Cal
I didn't even realize that Rockingham had a drag strip. I always thought of it as the NASCAR original oval track. Judging by Google Maps, it looks well laid out and the track itself seems well maintained. I used to go by there when my son was going to UNC Pembroke but that's too many miles to put on the ZL1. I really have to get a trailer this year and trade up to a 3/4 ton truck. Then I can go wherever the mood takes me and start tracking at the road coarses. I'll probably be back at Coastal Plains Dragway the next time we have a weather window. This weekend looks shot, though - socked in Sunday. --Cal |
02-02-2018, 07:38 AM | #4 |
Shifts under load
To me, Rockingham is a much better track and about 15 minutes further for me. They hardly ever do TNT, so you gotta watch their schedule. I've done 3 HPDE events now at Roebling Road Raceway and absolutely love it! It's a 5 hour drive, but my instructor is my best friend from my Navy days who lives in Savannah.
02-02-2018, 08:22 AM | #5 | |
Cal
I went to Bob Bondurant's Grand Prix Road Racing school in Chandler AZ before I picked up my ZL1 to prepare for road courses. Unfortunately, I haven't yet gotten to run it on a road course. I fully intend to start this year, though. I'll probably start at closer tracks like NCCAR, VIR, and CMP before venturing farther once I get a truck & trailer. |
02-02-2018, 10:46 AM | #6 |
Shifts under load
I would do NC CAR for a while before doing VIR. Those elevation changes are no joke.
02-02-2018, 01:15 PM | #7 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
You got me Cal!! Lol! I thought you'd nailed the perfect run and got the first M6 low 11. Still great passes and awesome write up as usual.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
02-02-2018, 01:42 PM | #8 |
Drives: '17 ZL1 Join Date: Jul 2016
The 60' times for the M6 just kill any chance at a great 1/4 mile time. Almost every run I've ever done with mine has about a 2.1 60' time.
I still have my fingers crossed for a fix. I'd love to see consistent 60' times in the 1.7-1.8 range.
02-02-2018, 02:30 PM | #9 |
Cal
I hadn't really thought about the elevation changes at VIR but that sounds like a lot of fun learning to cope with the variations in traction. Good idea to hone my X and Y skills before jumping into the Z axis, huh? Bondurant tracks have a few blind hills and banked turns but nothing that dramatic. Thanks for the tip. At this point, anything with more than 4 turns would be great! NCCAR is the closest so I've gotta find a club that goes there to tag along with.
02-02-2018, 02:36 PM | #10 | |
Cal
--Cal |
02-02-2018, 03:58 PM | #11 | |
Cal
My best 60 ft times are 1.9xxx and almost always result in 11.7 1/4 mile ET or better. All my 11.8 ET or better runs had 2.0xxx or better 60' times. If I could get 1.7-1.8 or better 60' times I know I'd be in low 11 territory. I'm hopeful like you Travis but I'm not holding my breath... Cheers! --Cal |
02-05-2018, 04:57 PM | #12 |
Shifts under load
Correction, Rockingham is running this Saturday and the 24th. I'm planning on the 24th. My favorite HPDE group is www.justtrackit.net but they are only in the southeast.
02-05-2018, 06:25 PM | #13 | |
Cal
I'd just like someone to chime in here that's using or has used 26-inch wheels on a 6th Gen ZL1. Then I can know one way or the other if I'll have a problem so I can go ahead and order my new DRs. |
03-18-2018, 08:27 AM | #14 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Cool dragstrip log. Have you tried to run slightly higher rear tire pressure? My car liked 26-27 PSI (A10) with the stock rubber.
