Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 01-13-2017, 09:27 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: 6th Gen Camaro Airaid Dry Intake Kit 251-333
2016-2017 6th Generation Camaro Airaid Dry Intake Kit 251-333
Since the 6th Generation Camaro SS doesn't have enough horsepower already....right? If you are not happy with over 400 horsepower already then it might be worth a second look to upgrade your factory airbox to a high flowing unit like this Airaid Dry Intake Kit. Airaid 251-333 is designed to make maximum power out of your 2016-2017 Camaro. Dyno tests show that this Airaid will give you 10 additional horsepower and 10 lb torque.
The AIRAID MXP Air Intake System represents the ultimate in AIRAID’s cold air induction systems and delivers higher levels of horsepower and acceleration gains for specific Chevrolet Camaro SS models. This air intake starts with a replacement one-piece roto-molded air box that addresses all the shortcomings of the restrictive factory design. Housed inside the air box is an AIRAID premium air filter for outstanding air flow and filtration. Air is directed through a new air intake tube constructed of cross-linked, high-density polyethylene that is designed using extensive computer modeling to maintain proper mass air flow readings and calibration. Additionally, this MXP air intake system has a built-in velocity stack, which further promotes airflow. What this all means is that you get a simple-to-install, yet extremely sophisticated system to increase air flow while maintaining proper air-to-fuel ratios, thereby eliminating the need for recalibration after installation. Just bolt it on and go! This air intake system is backed by AIRAID’s No Hassle Lifetime Warranty.
This unit is not legal in CA.
Order here: 2016-2017 6th Generation Camaro Airaid Dry Intake Kit 251-333
southerncarparts is offline   Reply With Quote
