Old 03-17-2018, 09:31 AM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Gforce driveshaft
Which way does the slip shaft/joint go, front or rear of car?I can't see any pics of this installed
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 03-24-2018, 03:16 PM   #2
Dubchitts
Dubchitts's Avatar
According to gforce it doesn't matter.
It does matter, however if you have a BMR safety loop. If you do the slip shaft goes on the trans side on account on the slip end being a little smaller diameter. Otherwise the full 3.5" will rub, even with the spacers for the trans mount...or its my safety loop sucks
"Spitfire" 427ci
