03-04-2018, 02:15 PM | #1 |
Drives: ZL1 A10 Join Date: Dec 2017
Rear Camber
The solution for front camber on a ZL1 is the Moreno camber plates. What about rear camber? I understand that the max stock is around -1.6 or so. Any solutions to more negative camber in the back? I would think it would be beneficial to get to -2 at least.
03-04-2018, 04:23 PM | #2 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
Im not sure about the zl1, but i put bmr toe rods on my ss 1le which facilitated -2.5 camber in the rear
03-04-2018, 05:13 PM | #3 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
Our rear geometry gains camber when loaded (unlike the front). I’m running -1.7 rear and still wear the inside 1/2 the tire most on track. Also- 650hp needs all the surface are possible to lay down power, the more negative camber= the less surface are under accel. Mid-engined Porsches don’t need -2.5 camber in the rear, much less our cars.
03-05-2018, 05:24 AM | #4 | |
03-05-2018, 06:02 AM | #5 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
03-05-2018, 07:22 AM | #6 |
03-05-2018, 08:19 AM | #7 |
The long wheelbase, rigid chassis and good rear geometry means we don't need much camber or toe out back. I run -2.75-3.0 in the rear of my 964 C2 and a TON of toe in. Trailing arm rear suspensions (like an e36 m3) lose toe and camber when loaded up, unlike the multilink on our cars. You don't want to try and drive an e36 M3 with .10 degrees total toe in (SS 1LE track spec from GM) on the rear....
03-05-2018, 11:42 AM | #8 | |
03-05-2018, 12:00 PM | #9 |
03-05-2018, 09:41 PM | #10 |
03-06-2018, 07:57 AM | #11 |
E46 M3. I am thinking tire performance rather than car type. I will be the first to say I am new to the Camaro and have no idea what set up makes it go fast around a race track.
03-06-2018, 09:52 AM | #12 |
Drives: ZL1 1LE Join Date: Oct 2016
I would probably start with what GM recommends in the performance supplement and go from there. You can buy a cheap tire pyro and get your own data based off the tracks you drive etc. and adjust as needed.
03-06-2018, 11:13 AM | #13 |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
I'd echo Sean's comments.
I'm using the performance supplement track alignment and it worked well at Road Atlanta and RoadAmerica with Hoosier R7's. Recommend you start there. I run with some E46 guys and they do run a lot more rear camber. Looking fwd to seeing you at RoadAmerica this year!
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
03-06-2018, 02:12 PM | #14 |
All set for Fri/Sat with Northwoods Shelby group in July. Should be able to get the break in miles by then
