04-24-2017, 11:28 AM | #1 |
Drives: 2017 Black ZL1 (6spd) Join Date: Dec 2016
Questions on preparing a zl1 for track day
I'm just about at the break in point for my 2017 zl1 and looking to take it to a road course next month. From reading the manuals, it looks like I just need to change the oil and the differential fluid. Curious t know what others put there are using for their fluids and if there's anything else needed to get the car ready for the course?
thanks |
04-24-2017, 11:48 AM | #2 |
Drives: 2016 1SS Join Date: Jan 2016
All I see is replacing the rear diff fluid AFTER the first event. This clip is from the GM website (where I downloaded the owner's manual)
1SS, Black, Black Wheels, A8, MRC, NPP
04-24-2017, 12:14 PM | #3 |
Drives: 2017 Camaro 1LE Join Date: Sep 2016
the Diff you can do after the event. I'm not sure on the LT4, but on the LT1 they recommend a dexos 2 oil for the higher load on your motor. I'm sure it's buried in your manual somewhere OR call the service dept. to see if they can help.
2017 Hyper Blue 1LE
04-24-2017, 12:27 PM | #4 |
Yes. I've changed to Dexos2 as well (there a long thread about this topic). 0W40 /5W40 basically can handle higher oil temp.
04-24-2017, 12:54 PM | #5 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
If this is your first event the stock brake fluid will be fine but as you progress you'll definitely want to switch to a DOT 4 fluid like Motul RBF 600.
04-24-2017, 02:17 PM | #6 |
Drives: Red Hot track candy Join Date: Oct 2009
Eric is spot on. Use the factory fill for first event or two until you get up to speed. I ran factory fill for 4 or 5 full events before flushing with RBF6.
Additionally, I get the same amount of HPDE's on rear end. The engine oil I change every 3 events religiously and send it off for analysis. I'm using Xclean 5/40 Dexos 2 for track. I keep it in for DD also as I'm not doing many miles on street and have 1-2 events weekly. In the winter when things cool off, I actually stick with the Dexos 2 in a 5/30 Castrol Edge (SLR) in between events. I only do 2 events a month in most winter months as I hate wet tracks. The cars are not delicate little princesses.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
04-24-2017, 07:50 PM | #7 |
Thanks for the feedback. I'll have to read the posts on the dexos, as I'm just not familiar with it yet. Can you get dexos equivalents from local stores or is this a dealership only thing? I used to run Mobil one in my c6z, but looks like i gotta get a different version now.
04-27-2017, 08:26 PM | #8 |
I find it is simplest to order from Amazon. The Dexos 2 oils are just taking a while to get the licensing. I'm sure we'll find most of the Dexos 1 players putting out new containers soon, i.e. Mobil1, Rotella, etc. I don't, however think we'll see some very good blenders spending the money on the goofy-ass licensing, i.e. Redline, AmsOil, Lucas, etc... I would have no qualms using most of those one warranty is not a factor. You can get the Castrol at Wallymart and Autozone, or at least I can. The Motul I am ordering by the case.
04-30-2017, 07:43 AM | #9 | |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Thanks! |
04-30-2017, 08:37 AM | #10 |
I used to be Dragoneye...
Valvoline SynPower 5W-40 is now Dexos 2 certified and another option, including Motul.
04-30-2017, 08:42 AM | #11 |
Drives: 2017 ZL1 Join Date: Oct 2016
Are we still using the additive to the diff (avoided grinding noises back there for me)? We used to do this in the c5 z06.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
04-30-2017, 08:40 PM | #12 |
Drives: ZL1 1LE Join Date: Oct 2016
If you use GM's spec diff fluid for the eDiff it comes with fluid in it. I would HIGHLY recommend you change your diff fluid before your first event. I and many other 1LE owners had tons of gunk after 1k miles. It's becoming common knowledge in our section to change diff fluid no matter what at 1500 miles.
I've swapped to Motul 5w40 and will be using that oil full-time from now on. Depending on your driving level, you may want to consider flushing brake fluid as well. I'm currently using SRF.
05-04-2017, 09:58 PM | #13 |
What about this 'Underbody Air Deflector Tire Dam Kit'? It shows a picture of the rubber mounts on the edge of each front side under the front spoiler, each with 3 screws. Are these rubber pieces supposed to come off for the track driving to help improve the airflow, and then put back on after? I don't have any special kit that says the car comes with in the manual.
03-08-2018, 01:54 PM | #14 | |
Drives: 2018 ZL1 1LE NGM Join Date: Dec 2017
Thanks! Peter |
Thread Tools | |
