06-13-2019, 01:28 PM | #1 |
Drives: 2019 ZL1 1LE Join Date: Mar 2019
GY3R’s, running less camber for better life
Has anyone tested running less camber on the front on the GY3R’s?
I’m throwing these tires away with what looks like another 4-5 sessions of thread left because the inside cords. So I’m thinking of trying to run less negative camber upfront and see how that goes. I’m at -2.8, so considering backing of to -2.3/-2.5 Last edited by Black E; 06-13-2019 at 02:33 PM. |
06-13-2019, 09:57 PM | #2 |
Drives: 911SC Join Date: Aug 2018
What you’re describing is a toe issue, not camber. I run 2.6, zero toe and zero issues.
06-14-2019, 06:48 AM | #3 |
06-14-2019, 06:50 AM | #4 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
06-14-2019, 08:22 AM | #5 |
Drives: A few Join Date: Oct 2017
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
06-14-2019, 08:42 AM | #6 |
What do you like.... .05 toe in rear works pretty well for me
06-14-2019, 09:08 AM | #7 | |
Most recent alignment for the ZLE was Front: -3.0 camber 0 toe Rear -1.9 rear camber .24 total toe in (.12 per side) |
06-14-2019, 10:30 AM | #8 |
Drives: 2018 ZL1 1LE Join Date: Dec 2016
06-14-2019, 11:02 AM | #9 |
Well the recommended track settings calls for +- 0.1-0.05, so is not like 0 is WAY off.
But for the subject of front tire inner wear, 0 toe is most ideal, no? |
06-14-2019, 11:50 AM | #10 |
Rear toe aids stability, especially on track. 0 rear toe will have the tendency to make the rear feel snappy and to not slide progressively. Our cars have a long wheelbase and are very rigid cars, so GM doesn't call for a ton of rear toe, but it is important to have some toe in on the rear axle.
06-16-2019, 06:07 AM | #11 |
Drives: 01 Z28, 1990 NASCAR Busch North Car Join Date: Jul 2018
Black E -
While toe can cause this, don't throw out your original idea of less camber to reduce inner tread wear. If you aren't cornering hard on the street and you have normal tire pressures, of course you will have more load on the inner part of the tire with higher camber. ...think about it - if you could get -10 degrees camber it would be even more severe; your situation is just less at -2.8 degrees. I woke up this morning planning to determine a decent compromise for alignment for the '17 1LE that I bought yesterday. I plan to daily drive it to work (+80 miles roundtrip) and run track days and possibly time trials. Will think more about alignment specs later today - plan to drop off the car tomorrow for the alignment. Back in the "olden days" with my 1988 IROC Camaro, I used to change camber before and after track events and marked the suspension with the street and track settings. That was easy - jack up the front of the car, loosen the upper bolts, push the top of the suspension towards the correct paint marks, then retighten the bolts. Done. I haven't looked at this 6th gen to see if this is practical. Anyway, going to zero or marginally positive toe and a reduced camber will definitely show a difference in wear on the street. But of course, it will also reduce front traction under cornering loads on the track... Right now I am leaning towards 2.2 neg, camber and a tiny amount of toe out in the front as my starting point. But I need to circle back around to this later today when I get time. Anyone know what the factory alignment specs are for street driving for these cars? Last edited by KeithO; 06-16-2019 at 06:18 AM. |
06-16-2019, 07:37 AM | #12 | |
06-16-2019, 08:46 AM | #13 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I run maxed F at 2.6 and R at 1.6 with a very slight toe out F and toe in R. But by all accounts the car doesn't need any F toe out it seems. I dont dd my car much, but drive to/from tracks 200-500 miles each way. Track wear is good right across. 2.2 F might be a good compromise, but you'll likely get some excessive outside shoulder wear while on track. Given your dd distances it might be a good idea to get a second set of rims and harder tread tire for dd? |
06-16-2019, 08:52 AM | #14 | |
Btw 0.9 toe out on a single wheel is huge... |
