Old 02-24-2018, 04:26 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
.040 head gasket on LS3
Anyone running a Cometic 0.040 head gasket on a stock lS3?
zz430camaro is offline   Reply With Quote
Old 02-24-2018, 05:29 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
We do a lot. Be careful on piston to valve clearance depending on cam. You will lose a little over .010 clearance.
Rhino79 is offline   Reply With Quote
Old 02-28-2018, 06:40 PM   #3
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
compression ratio!!!
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-28-2018, 06:49 PM   #4
sixty9fordkiller
you know what, Rick Crawford created a mean street/strip proven setup for the G8 guys that consists of stock LS3 heads ported and milled to 64cc on 6.0 blocks with a cometic 0.040 gasket with what they call a "little lunati" cam (223 intake duration) and a stock intake manifold with the rod mod like the one GPI does and those fellas are running low 11's/high 10s with a stock 3.27 or 3.45 out of a 5th Gen camaro with a very streetable heavy (but fast) NA car. Its good stuff!
Bone Stock
Old 02-28-2018, 07:08 PM   #5
zz430camaro
Drives: 2015 1LE
Yep, that is kid of what I am modeling my engine after. I am doing Street Smart ported heads from Land Speed Cylinder Head Development, GPI fully ported and rod mod intake (same as RCR intake) and a small 225/236 duration cam. Should be a great street set up but time will tell, hoping to button this thing up in the next month.Name:  20180228_110507.jpg
Old 03-01-2018, 09:16 AM   #6
Punisher_ATX
Drives: 2010 SS
How much was milled from the heads when they did the porting?
Punisher_ATX is offline   Reply With Quote
Old 03-01-2018, 09:41 AM   #7
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
I just dropped a Cometic .040 Gasket w/ GPI Ported heads milled .050 on my buddy's LS3 GPI SS3 cammed 5th gen to build compression...
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 03-01-2018, 09:52 AM   #8
sixty9fordkiller
.050???? woooooooo! thats about a 12.4:1 SCR
Who needs pump gas anyways!
Bone Stock
Old 03-01-2018, 09:56 AM   #9
sixty9fordkiller
did you get their new 13 degree heads? or did you get their ported LS3 castings and flycut the pistons?
Bone Stock
Old 03-01-2018, 10:22 AM   #10
bhillakaiceberg
Just regular ole Ported castings and flycutted...
Built/Tuned by Me
Old 03-01-2018, 02:13 PM   #11
zz430camaro
Drives: 2015 1LE
0.010 for clean-up, finished chamber is 68 cc
Old 03-01-2018, 05:04 PM   #12
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
Just for comparison on what I ended up with Landspeed heads
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 03-01-2018, 05:32 PM   #13
zz430camaro
Drives: 2015 1LE
Cool, I ended up getting a 0.045 gasket so I should be right around 11:1 compression wth 0.038 quench height.
Old 03-01-2018, 05:38 PM   #14
zz430camaro
Drives: 2015 1LE
It was hard to resist getting the intake runners fully ported but everytime I saw dyno data from his heads it really worked and from your results I would say that holds true. Most of the flow increase happens right under the valve.
