03-13-2016, 09:00 PM | #1 | ||
Drives: 1991 Camaro 383 stroker Join Date: Dec 2014
BC Racing Adjustable front and rear coilovers - VIDEO!!!
Here are two videos on the step by step process of installing BC Racing adjustable coilovers in the front and rear of a fifthgen camaro...enjoy
03-18-2016, 08:18 AM | #2 | |||
Drives: 2010 Camaro SS 5th Gen 6spd SC Join Date: Jun 2015
You go thru every step perfectly. I wish I had this when I Installed my coilovers. I'm most likely going to have to reinstall mine because probably going to change rear spring rates/front SWIFT springs upgrade w/new shocks to match. This will be good to have to make sure i do it properly the second time also. This should help a lot of members on here to feel more confident to do it on there own at home.
10' LS3 Camaro 2SS (blacked out) - Edelbrock Supercharger, ZL1 rims, 275/315 tires, XS Power LT headers, 3" exhaust, twin tips, Edelbrock CAI, ZL1 fuel pump/ADM FPCM, VMax ported TB, JRE fuel mod, TR6ix plugs, ZL1 spoiler/splitter/grille, KW V1 coilovers, BMR sway bars, strut tower brace, trailing arms, toe links, Prothane radius arm & subframe bushings, Slotted rotors, Hawk pads, SS brake lines, HURST short throw shifter, Scosche dash kit, Pioneer 7" radio, backup camera, Dyno - 520 rwhp/tq
03-20-2016, 03:55 PM | #3 |
Great video !! Should place this in the DIY section How's the ride now since the install compared to your previous set up?
The DREAM is free... It's the HUSTLE that is sold seperately
03-21-2016, 08:56 AM | #4 |
Drives: C6 Corvette Join Date: Sep 2013
Just did mine over the weekend. kept this video on my tablet next to me the whole time. Doing this install was so much easier than I expected because of it.
not to thread jack....but I've never had a CO suspension before and not the most knowledgeable on setting them up. They seem very bouncy to me. On full hard setting the car bounced like I was on cut springs. Full soft setting and it was a lot better but too soft for the performance feel I wanted. Did 5 clicks from full soft and it is good but if the road gets bouncy it feels like I'm driving on a trampoline. I set the springs like he did in the video...by hand as tight as I could and then used the tool to make the spacing between the two locks before tightening down.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
03-21-2016, 10:09 AM | #5 | |
03-21-2016, 10:38 AM | #6 | |
03-21-2016, 02:26 PM | #7 |
Drives: 2010 2SS/RS Join Date: Jul 2014
For the BC coilovers when putting the fronts together aren't you suppose to take off the upper spring isolator off of the upper spring mount? In the video it was left in place. For the coilovers I have seen that reuse the stock upper mount, you take the spring isolator off since the coilovers have their own.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
03-21-2016, 02:59 PM | #8 |
Still trying figure out the best ride quality on these BC BR's. Still talking to several people to find out what is the best spring rates, options.
03-21-2016, 03:00 PM | #9 | |
03-21-2016, 04:23 PM | #10 | ||
03-21-2016, 04:32 PM | #11 | |
Current car
03-21-2016, 04:32 PM | #12 | |
03-21-2016, 04:50 PM | #13 | |
Do you feel your poor ride quality is just the front or both front and rear?
03-21-2016, 08:20 PM | #14 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
