05-09-2017, 03:54 PM | #57 | |
Drives: 2017 1ss m6. Blue..... Join Date: Mar 2017
05-09-2017, 08:07 PM | #58 | |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
Soldering can lead to embrittlement which weakens the wire and increases resistance. |
05-09-2017, 08:15 PM | #59 |
Deutch connectors all the way. It's sealed, it doesn't create resistance and you plug in to your unchanged factory connections. That's what we use at Cat and what I use on all my electrical automotive work.
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
05-10-2017, 02:10 AM | #60 |
Drives: 2017 2SS MRC NPP Join Date: Jul 2016
Amp connectors will blend in better with the GM wiring than the DT stuff. Uses the same pins and sockets. It's a little cheaper too. The crimpers are about $300 for the real deal although you can buy crappy ones from amazon.
Cheaper would be to tool up and use delphi 150 gt or something like that.
2017 - Black - Silverado 1500 Crew Cab - LTZ
4x4 - 5.3 - 6spd - 3.42 - black leather Sold 8/31/2017 2017 - Silver Ice Metallic - 2SS A8 - MRC - NPP - black leather 1996 - Sebring Silver - Trans Am - WS6 383cid - Ported heads - Bullet Cam - 4l60e - Yank SS4000 - 3.90 gears - Kor3 Brakes Built and tuned by me 445rwhp @ 6400rpm - 11.4 @ 122mph Collecting parts for 408 LS3 and 500rwhp. |
05-10-2017, 06:24 AM | #61 |
Just use wire nuts and black tape like the rest of us.
Seriously, good luck. It certainly has an awesome look under the hood now.
05-10-2017, 10:34 AM | #62 |
If you can get your hands on deutch connectors I'd go this route vs what I said previously. This is also what we use at work but will probably cost more.
05-10-2017, 06:58 PM | #63 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Ended up crimp and shrink wraps and electrical tape wrap.
Extended my map sensor wires and solenoid purge so they could be connected to manifold.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
05-10-2017, 08:57 PM | #64 | |
05-11-2017, 06:28 AM | #65 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Negative. Most full bolt on builds are high 400's--PRAY for instance, hit I believe 498 or 499whp with his bolt on A8. Recently a H/C/I 6th gen made 557whp with a relatively mild cam. Back in the LS3 days, you'd need all those mods to break 500 reliably.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
05-11-2017, 10:49 AM | #66 |
at the crank or wheels?? At the crank yeah that would be easy especially if they made a updated ls7 with DI , and called it the lt7
05-14-2017, 10:30 PM | #67 |
Up and running today
Tunnel Ram is up and running today.
Definitely a different tone that sounds amazing. I will not say what I think I gained till dyno later this month. Does not feel like it lost anything, so that's good. I ended up putting it all in by myself and got it done. Was in no rush and took my time and learned a lot. I ended up painting it gun metal, to match my darker over all theme. So, I might be the first tunnel ram on a 2016 SS that I am aware of. Different is what I want and I think I did that I n spades. I have a few future ideas to add to the motor at a later date. I have started cleaning up lose ends, rear firewall, and need to get a front plumbing tube squared away. Work in progress.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 05-14-2017 at 11:15 PM. |
05-14-2017, 10:31 PM | #68 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
What tires are those? Nittos?
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
05-14-2017, 10:42 PM | #69 |
[QUOTE=bybcous;9726787]What tires are those? Nittos?[/QUOTE
Toyo R888
05-15-2017, 11:44 AM | #70 |
Looks great man! I'm curious to see how the numbers fall with a dyno.
