08-30-2017, 09:47 PM | #141 |
Sarcasm loading --------
Underhood pics???
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
08-30-2017, 09:54 PM | #142 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I am officially, "Back in Black" now as AC/DC says. Took the wrap off today.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
08-30-2017, 10:05 PM | #143 |
Under the hood pics. Can't wait to install 105 TB and change to a 105 top on tunnel ram. Then get my air filter squared away with a copo style air filter right in front of TB. I will have a Roto fab used air intake for sale. PM me if your interested in buying used Roto Fab in a few weeks. $225 US funds Firm and fair price.
Night owl love your signature!!!!! Sideways is for show, but so cool.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 08-30-2017 at 10:16 PM. |
09-02-2017, 09:15 AM | #144 | |
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
09-14-2017, 06:41 PM | #145 |
Update - added front air intake today.
I had called Copo Parts 3 times with messages and e mails. The owner does not answer his calls or e mails. I wanted the front Copo air intake from the Copo Patrts store. 3 months later I made my own. Needed a MAF/Mass air tube with the opening to put in MAF. So I ended up ordering a tube and cutting to fit my application and drilling a hole for input tube. I bought a K&N air filter at local speed shop and lengthen my wires to MAF/Mass tube. I ended selling my Roto Fab on the fourm. I got a check engine light at the start, pulled the power at battery and it rebooted with no check engine light after an hour drive and a few restarts. Noticed and expected it to run a little rough after change in MAF/Mass relocation, only a touch. Will get tuner to smooth it out and check air/ fuel tables. Plan to add E85 next week and then dyno if tuner can get me in, will be interesting to see numbers but more interesting to see times at the track and that's where the proof will be will be in the build.
09-15-2017, 07:04 AM | #146 | |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
The exhaust sound is intoxicating. I admire all you did and know it was a TON of work and some rework but it has really paid off. Congratulations on a super tight build. You should be very proud of it!
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
09-15-2017, 10:09 AM | #147 | |
09-15-2017, 11:57 AM | #148 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Looks great!! Love that front mount air intake.
Kindness and compassion #OthersFirst |
09-20-2017, 04:20 PM | #149 |
Had to redo the wiring for MAF sensor, had a low voltage check engine light on. Soons as I did the re-wire the code went away and the idle smooth out.
Here is a link to a video of cold start on car. https://m.youtube.com/watch?v=iP9CAk742lI
11-01-2017, 11:38 PM | #150 |
Fall/Winter Update
Well today I added some exhaust cut outs for the spring track days. I also reconfigured my rear exhaust system. The exhaust was simply to loud for street use and that’s why I added the cut outs for the track. I added flowmaster moderate mufflers that did the trick for street use and got rid of the flowmaster outlaw mufflers. So to recap I have no cats, kooks longtube headers, 3 inch stainless steel, no AFM or mod valves or NPP valves which I totally deleted. The car is still plenty loud. I will get some videos up soon.
My winter project this winter is to add a Procharger, NOS system for the Holley High Rise with a stand alone fuel system. E85 with a upgraded fuel pump. Meth and water tank. Probably high stall added to the mix too. Then work out the kinks with the tuner and the testing starts to make the system run as smooth as I can get it. And yes I know I am changing my mind about keeping it a NA Build, I have a target in mind to reach and just will not get there if I stay NA.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 11-02-2017 at 12:01 AM. |
11-02-2017, 01:11 AM | #151 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Pro charger. NOS. Stock bottom end ?
11-02-2017, 07:47 AM | #152 |
The plan is to keep it at around 750 hp. So I may only need a 50 NOS shot if the Procharger delivers there rated 170 HP added spec. The stock bottom end should be fine at that HP.
11-02-2017, 09:10 AM | #153 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
You may have answered this or addressed it in an earlier post but, did you keep the stock converter with this build?
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
11-02-2017, 12:07 PM | #154 | |
Still with stock converter and no problems. High stall maybe in the future, had one on another car in the past and the high stall did not last that long. Maybe just unlucky with that converter but the feeling has not gone away and so far very happy with A8 and stock converter.
