Old 07-09-2015, 11:56 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Replacing Halo Led?
Has anyone been successful in doing this? I don't understand by companies like AAC don't offer such option? I would be open and interested in taking part in a mod like this. I would prefer the 2 led's for a brighter halo ring as seen in the newer camaro SS models.
Nighthawk89 is offline   Reply With Quote
Old 07-10-2015, 09:56 AM   #2
ka1
ka1's Avatar
Drives: 2011 2SS
That is exactly how the Nightowl kit is installed.
ka1 is offline   Reply With Quote
Old 07-10-2015, 10:45 AM   #3
Nighthawk89
I had heard about this kit previously but never looked into it when i came across the name. I will look into it right now.
Old 07-10-2015, 11:05 AM   #4
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
I had the JDP now the Night Owl. I have done 4 sets pretty easy.
1. Remove the wheels, and liners
2. Remove the bumper cover
3. Remove the head lights
4. Open the top and bottom via the access area
5. Cut the old LED
6. Un-screw plastic piece holding the LED in plce, lift it up and slide out the old and slide in the new.
(2 of the 3 screws are a PITA, and getting in the LED can be a pain just take your time).
7. Slide the new LED plug through the small access area
8. Close it up and put the headlights back in.
I cannot stress enough take your time and go slow.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 07-10-2015, 11:11 AM   #5
Nighthawk89
5. Cut the old LED
Does this require completely breaking open the headlight housing? Does this leave the headlight housing more susceptible to that dreaded fogged housing?
Old 07-10-2015, 11:13 AM   #6
01pewterz28
#TeamBeckyD
No the two access panels unscrew so it closes up no issues.
#TeamBeckyD
Old 07-10-2015, 11:14 AM   #7
Nighthawk89
How long has this kit been out and has there be any failure in the kit (Led, ETC)
Old 07-10-2015, 11:45 AM   #8
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
I have had my Night Owl kit for about 2 years.. and not one failure or complaint.
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 07-10-2015, 11:46 AM   #9
Nighthawk89
Is the white much brighter over stock? Closer to the newer year camaro's? And is it a white white or like an off white?
Old 07-10-2015, 11:48 AM   #10
13FastBlkSS
IMO its brighter, and the phone application (you can control the kit via iOS app or android app) allows you to fine tune the white color or any color.
Build#24869
Old 07-10-2015, 11:49 AM   #11
Nighthawk89
Who installed yours?
Old 07-10-2015, 11:50 AM   #12
13FastBlkSS
I did, in my garage.. its easy to do as long as you follow the instructions and take your time.
Build#24869
Old 07-10-2015, 11:53 AM   #13
Nighthawk89
Im contemplating this kit forsure seeing as how i have pretty good access to my headlight housing lol
Old 07-10-2015, 11:53 AM   #14
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Guys first off let set up so all will get it.
2010-13(and all ZL1) headlights use 1 LED per headlight.
2014/15 use 8 LED (US cars) 10 LED for the Ero cars, so we older headlight owners will never have the same bright halo ring as the newer headlight cars.
all the old headlight use a star mounted LED in white, in the 5000K range, you can get them from lots of places, and there in the $10-20 range, the ones that are sold in the kits are RGB, more then one color, if that is what you want then get a kit, if all your looking to do is replace the LED no need to buy a kit.
2SSRS@Gen5diy is offline   Reply With Quote
