03-01-2011, 08:12 PM | #1 |
Posi traction?
I have never done a burnout, so I didn't know. Does the LS have a Posi-traction rear end or a limited slip?
03-01-2011, 08:13 PM | #2 |
My Cousin Vinny?
03-01-2011, 08:21 PM | #3 |
Drives: Really Slow Join Date: Apr 2010
Manual, yes. Auto, no
03-01-2011, 08:40 PM | #4 |
Like said if it's an auto then no. If manual then yes. Also for those that might not know. Limited slip and Posi-traction are the same thing. Just different names. The auto 6cyl gets an open differential.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
03-01-2011, 08:51 PM | #5 |
Thanks for the info.
04-12-2011, 05:01 PM | #6 |
I have a 1LT and when I do a burnout both tires spin it doesnt mater if its on dry or wet road and on a wet road when it shifts in to 2nd gear it goes sideway so I would think it has a limited slip and it's an automatic.
04-12-2011, 05:35 PM | #7 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Automatic no, manual yes, option G80 see the chart on this link. Standard on both A6 & M6 on the SS models.
http://eogld.ecomm.gm.com/NASApp/dom...age=7&butID=16
04-12-2011, 05:41 PM | #8 | |
04-12-2011, 05:49 PM | #9 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
An open diff applies equal amounts of torque to the wheels at all times. So long as both wheels start spinning at the same time and keep the same rotation you will likely get both wheels to spin. Now try doing a burn out and turning slightly, you will see that only one wheels spins and that is the limitation of an open diff.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
02-20-2015, 06:41 AM | #10 |
Wingnutt
Drives: 2011 Chevy Camaro SS/w RS package Join Date: Apr 2011
Posi traction and Limited slip are not the same
02-20-2015, 07:01 AM | #11 |
Yeah... they pretty much are the same thing. "Positraction" is GM's name for Limited Slip Differential (LSD). My '63 Studebaker called it's LSD, "Twin Traction". Here's a list of what other car companies call their LSDs:
Factory names[edit] In the 1950s and 1960s many manufacturers began to apply brand names to their LSD units. Packard pioneered the LSD under the brand name "Twin Traction" in 1956, becoming one of the first manufacturers. Other factory names for LSDs include:
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
02-20-2015, 08:53 AM | #12 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
02-20-2015, 09:50 AM | #13 |
Drives: 2SS 45TH,gfx,blade spoiler,h grille Join Date: Jan 2010
when I ordered my 2010 V6 I tried any way I could and could not get the limited slip with the automatic. only with the manual. there is no option for LSD with the automatic.
02-20-2015, 11:09 AM | #14 |
Drives: car Join Date: May 2008
Easy way to tell:
Get the rear tires off the ground and put it in neutral. Spin the tire on one side. If the other side spins the same direction you have Posi/limited-slip etc. If the other tire spins the opposite way you have an "open" non-posi rear. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Looking for more traction? I recommend Pfadt Rear Trailing Arms! | Apex Motorsports | Suspension / Brakes / Chassis | 13 | 07-17-2010 05:29 PM |
Traction Control ??? | BabyHauler | 5th Gen Camaro SS LS LT General Discussions | 12 | 03-28-2010 07:00 PM |
Problems with Traction Control | dunnz28 | 5th Gen Camaro SS LS LT General Discussions | 12 | 12-18-2009 09:34 PM |
Any run a Posi in their daily driver? | 2ndgenz28 | Off-topic Discussions | 4 | 10-16-2009 06:56 PM |
Camaro LS Question: Traction Control | Beau Tie | 5th Gen Camaro SS LS LT General Discussions | 2 | 10-07-2008 12:24 PM |
