10-09-2014, 05:09 PM | #43 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Found this today... http://www.s4-mtm.com/images/925803_3.0V6TFSIengine.pdf Lots of decent info about some of the workings, and systems of this Audi unit.. Aside from mounting, I'll need to figure out a proper pcv setup (That bung looking thing on the bottom of the unit is a pcv inlet into the super charger.), and figure out a way towork the bypass valve... Looks like it might just take a 0-5v signal to open close. |
10-09-2014, 07:09 PM | #44 | |
Drives: 2010 Camaro LT2/RS Join Date: Apr 2011
10-09-2014, 11:43 PM | #45 |
Oops, I must have forgotten about it and when I started doing more research when the Audi unit showed up today got excited again when I stumbled upon it through searching the interwebs...
So the stock Audi pulley measures appx 2.8", and with a 6" pulley on the LFX it should make about 7.9psi boost spinning the sc to ~15,451 rpms which would put it in about it's 65% efficiency range. I really feel like the 1320 is undersized for an LFX engine based on this math. Seems like absolute max boost with a 1320 would be 12psi, and you'd be running the SC at about 18,200 rpms in about the 55% efficiency range. Hopefully the bricks are extra efficient in this thing. I drew up and cut out all of the flanges I need for the intake today. I'll have to take some measurements off of the supercharger, and the engine to figure out the offset of the flanges to get the drive to line up, and then build some sort of fixture so I can begin trying to fit the tubes to the offset flanges. |
10-10-2014, 09:56 AM | #46 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
11-02-2014, 08:15 PM | #47 |
Drives: 2015 Camaro LS M6 Join Date: Sep 2014
Any progress?
11-03-2014, 08:48 AM | #48 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
I just don't see the 1320 being a good super for this car, seems like you'd be spinning the crap out of it. That 1900 wants to be used!
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
11-03-2014, 03:09 PM | #49 |
Silver Ice
This makes me very very happy. You would have many buyers for this unit. It would be such an easy install and wouldnt need any supporting mods. Great work man.
11-04-2014, 10:45 AM | #50 |
11-04-2014, 12:19 PM | #51 |
True, but that's part of the fun of having a positive displacement supercharger... getting to pulley down for more boost. Which is why the TVS 1900 would be epic. Though, if this can break 400whp and, eh, 420 ftlbs, it is a definite possibility... Just, again, you'd be spinning the crap out of it to make enough boost.
11-05-2014, 07:35 AM | #52 | |
Silver Ice
11-05-2014, 08:10 AM | #53 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
If you end up making the Audi piece work you could possibly look to just make all the supporting parts, lower manifold, pulleys, brackets etc part of a kit and have the end user source the S/C from a used parts dealer.
To put it plainly this will limit your liability. If you went new it would most likely end up too pricey. Going used opens you up to failures. Just a thought. I'm watching because a Colorado might be in my future as a work truck. One last thing I tried something similar for the old 4.3L in S10's and stopped when I realized that my target audience was broke. This audience is doing a little better. Good luck I think you might be on to something here. Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
11-05-2014, 08:48 AM | #54 |
Could this be a new thing for an LFX engine for a top mounted Supercharger ???
ah man this would be the best news ever.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
11-05-2014, 06:20 PM | #55 | |||
None to report... It's a winter project... It's not going to happen over night. I'm still thinking about the best way to go about the intake manifold design/fab.
I do agree, the 1320 is probably not ideal, but as previously mentioned, for a budget deal that's compact and self contained, It might just be worth the effort. Quote:
11-05-2014, 07:17 PM | #56 | |
