01-27-2013, 03:14 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
TB cleaning questions
How often should the TB be cleaned? My car has 25,000 exactly on it.
01-27-2013, 05:55 PM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Is it dirty? Have you taken the intake tube off and checked inside? If it is, a quick couple shots of carb cleaner will clean it like new. Do you have a catchcan? If not, that will DRASTICALLY reduce the amount of soot your TB sees.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-27-2013, 06:48 PM | #3 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
If you don't have a really efficient catch can like the RX, your TB is likely very dirty. Unless there is enough build up to cause idle problems you don't have to clean it. That said, the residue from the PCV along with heat baking it on will require throttle body cleaner along with a shop towel to get it clean. I have 47k miles on my car and have cleaned my throttle body at least three times.
She is only memory now. |
01-27-2013, 09:57 PM | #4 |
Drives: 2011 Camaro 2SS/RS M6 Hurst RJT Join Date: Apr 2011
I cleaned my throttle body last week with TB Cleaner. At 27k miles it was pretty dirty. Whatever you do, don't use the Wynn's TB cleaner. That shit screwed up my O2 sensors. That same night my SES light came on with a lean code, causing the ECM to command more fuel, and thus making the car run rich. Wynn's = shitty ass product. That's coming from an auto tech.
01-28-2013, 07:28 AM | #5 | |
01-28-2013, 12:25 PM | #6 |
I actually didn't use a lot. Just a few sprays. The cleaner I used is designed to be used with the engine running. And it specifically says on the back label of the can "Formulated to be safe for oxygen sensors, catalytic convertors and coated throttle bodies." It would probably be best to use the GM stuff.
01-29-2013, 12:07 AM | #7 |
Thanks for all the feed back you guys. I've actually never cleaned it.. ive kept up with my CAI but never the TB.. I'm not familiar with what a "catch can" is.. Is it pretty easy to clean the TB?
01-29-2013, 02:31 AM | #8 | |
Search Ninja
To clean it with TB cleaner, just loosen the clamp that holds the intake tube to the TB, then take the tube off. The TB is right there in front of you. If you see a lot of soot around the blade, spray it and watch it disappear. Push the blade open and spray the backside of the TB blade till clean. Then spray around the throat to get the soot off it as well. Put the intake tube back on and fire her up. Like I said, it may run like shit for a few seconds but just rev it up to keep it from dying. It should clear up quickly.
01-29-2013, 07:41 AM | #9 | |
2. Disconnect the electrical connector on the passenger side of the TB. 3. Remove the 4 TB bolts (10mm socket) 4. Take the TB back to your bench or outside. 5. Spray with TB cleaner (I used CR brand) 6. Wipe stubborn areas and rotate the blade to get to the tight spots. 7. Wipe out the intake manifold (Blue shop towels on a roll) 8. Put the TB back on with the 4 bolts and tighten to 89 inch pounds or about 7 foot pounds or just snug without a torque wrench 9. Plug in electrical connector 10. Reattach the intake duct. On a stock box don't forget the PCV hard line. Looks like a lot but only takes a few minutes. And oh the smell of TB cleaner.
01-29-2013, 05:11 PM | #10 | |
Is seafoam safe to use if I only have 25,000? And where is the intake tube? |
01-29-2013, 06:13 PM | #11 | |
The intake tube is the tube connected directly to the throttle body.
01-29-2013, 06:29 PM | #12 |
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
01-29-2013, 10:57 PM | #13 | |
Cool! Thanks for all the help. I'm going to be doing the sea foam in my tank of gas tomorrow and getting a good TB cleaner and a rag to clean the TB and intake manifold.. do I forsure need a tork wrench for the TB? |
01-30-2013, 12:12 AM | #14 |
Search Ninja
No you don't need a Tq wrench for the TB bolts. There's a tq value for pretty much every nut/bolt on the car and some like to use them. TB bolts aren't one of those "need to be tq properly" areas. 7 ft/lbs isn't much so just snug them up tight. Those bolts are going into plastic so don't get overzealous with your tightening. Common sense plays a HUGE role in most engine work.
