05-14-2018, 05:14 PM | #1 |
Drives: 2010 2SS/RS A6 CGM Join Date: Jul 2010
Not making expected HP - Help!?
TL;DR: I'm making what I think is about 40-50hp less than I think my mods should. Questions at the bottom.
I'm hoping someone with a little more experience out there will give me a hand. I've been the proud owner of an A6 2010 2SSRS since fall of 2009. After the warranty fell off I started modding with the help of a friend in my garage. All I've done is bolt-ons: ADM scoop, CAI intake, PTB, Kooks LT headers and HFC's and a Solo cat-back exhaust with a JRE tune. No baseline dyno run. Last weekend was my first opportunity to put it on a dynojet and I was pretty disappointed with my numbers. Best of 2 pulls was 336hp and a bit more torque. (sorry, at work and don't have the sheet in front of me). From what I'm seeing online that's only slightly above stock, and in some cases right in line with the stock setup. So I'm now under the impression that something's wrong and I'd like to figure it out and fix it. Hoping someone can chime in and give me some ideas. The CAI intake has been on the car for probably 6 years and I've never cleaned/re-oiled it. It couldn't be where that 40-50rwhp went, could it? Obviously it's past time and tops on my list of things to correct... like, tonight after work, lol. CAI filter was slightly damaged (no holes, just deformed the nose of the cone slightly and put a few wiggles in the pleating near the cone) during an accident last fall. Repair shop must not have thought it was a big deal. Were they wrong? Should I spend the $50 and get a new filter? With no catch can and 62k miles I'm assuming my intake manifold has accumulated some gunk over the years. Could that be causing this kind of significant power loss? The shop that did the dyno run said the tune looked OK (lines looked kind of sawtoothed, but not terrible) but could use some fine tuning, likely because of environmental differences between IL and NJ. Likely story or sales pitch? Any other ideas about what might be wrong? Did I maybe just get a weak engine from the factory and not know it till now? Are my expectations just wrong? Thanks in advance for any help or advice you guys can provide. I love the car regardless and have had a blast with it, but I'm obviously a little irritated with the result of $2500 worth of mods and hours spent sweating and bleeding, lol.
Mods: Heritage Grille, '69 SS emblem in grille, CAI intake, ADM scoop, vMax PTB, Kooks LT headers w/ HF Cats, Solo Mach-XL cat back |
05-14-2018, 05:48 PM | #2 |
Drives: 5th gen Join Date: Oct 2016
What was ambient temp and what correction factor was used? I doubt it's the filter or intake. It's likely the tune, either a very conservative timing table at WOT, or maybe you were getting some KR on the dyno and it was pulling timing during the runs. How experienced were the people telling you it looked ok?
05-14-2018, 05:49 PM | #3 |
Drives: 2011 Camaro SS Join Date: Nov 2014
have you ran 87 gas in your car lately? or tried the fuse pull just in case you got bad gas somewhere? you might be stuck in low octane table.
05-14-2018, 05:56 PM | #4 | |
I just reread the OP, am I understanding correctly that they didn't log the tune, they just told you it looked ok based on the dyno graph and A/F ratio? If so lol |
05-14-2018, 06:41 PM | #5 | |
05-14-2018, 06:54 PM | #6 |
Could be, I have no experience with Jannetty, but from looking at a decent amount of logs from reputable tuners I've yet to see one build a low octane table for a mild N/A setup
05-14-2018, 07:56 PM | #7 |
Drives: cars Join Date: May 2011
If there's spikes they don't know how to use the smoothing factor of the dyno software and without AFR data I'd trust your original tuner over their skills at operating a dyno. Dynos are numbers, that's it. Don't race paper.
05-14-2018, 08:00 PM | #8 |
Yep, only one table and that's for 93. I confirmed with Janetty when I ordered it That's all I run in it. Either shell or mobil. Their solution to the low octane problem was a separate tune for 91 that has to be flashed manually, lol.
Ambient was 65 and humidity was 70% with rain on the way. CF says SAE Smoothing 5. I'm too much of a novice to know what that means though, lol. You got me right when I said they didn't log the tune. They were just looking at the graph. It was a local Dyno shootout event so they weren't really looking into specifics at the time. They are pretty much the only speed shop in town and I don't have a lot of evidence to say how experienced they are. Of the 25 reviews they have on their Facebook page 22 are 5*, one 4*, one 3* and one 1* for banging up a spoiler. Make of that what you will, ROFL. So after the wreck last fall Is it possible the repair shop flashed me back to the stock tune/tables? I haven't noticed AFM kick in and it runs just fine. I would have thought I'd have AFM, a check engine light, and be running rough if they had. Sorry if I'm asking foolish questions. This is the first car I've done anything to. My background is in electronics, not combustion. I'm learning slowly. 😁. Thanks for the feedback! I really do appreciate it!
05-14-2018, 08:13 PM | #9 | |
Now here's what's probably a really dumb question... do they normally blow a fan on the intake to simulate airflow in motion when they do a pull? I honestly didn't watch the setup and had my eye on the car and the monitor. If that *is* a thing and it was aimed at the stock intake location then they did it wrong(because i didn't tell them)... scoop relocates the intake air from the upper grille to the lower grille.
05-14-2018, 08:17 PM | #10 | |
Bottom line is if you're concerned about it, have someone reputable and experienced log the tune and see whats going on |
05-14-2018, 08:26 PM | #11 |
The fan is for cooling not intake air. Not needed for a single dyno day pull.
05-14-2018, 09:14 PM | #12 |
Awesome. Thanks for all the info and advice! I didn't realize there were so many factors in dyno numbers. It all makes a lot more sense now. And for the shootout they wouldn't have been too worried about having everything perfectly set as long as everyone was tested the same. I'm guessing I'd have a better experience if I went in and had them do it legit in the shop.
Thanks again! Matt
05-14-2018, 11:24 PM | #13 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Those are almost stock pre tune numbers. Add a few hp in for your bolt ons. I think somehow the tune is bad.
05-15-2018, 10:09 AM | #14 |
Instagram: Sangstah
Either that or the dyno is way off calibration?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
