05-01-2024, 09:12 AM | #1 |
Drives: 2010 Camaro ss A6 "Chief" Join Date: Dec 2020
Fuse box Relocation Issue
My Camaros alternator failed a few weeks ago, and I thought it was a good idea to finally relocate my fuse box to inside my glovebox.
Finished up, everything works well except I am having an issue with my brand new alternator. Alternator was charging the battery very sporadically, while test driving, pretty much constantly draining the battery voltages. I checked all grounds, all new wiring, fuses etc. nothing would work. So as a last Hail Mary I decided to unplug the 2 wire harness connector that is on the back of the alternator so it can default to its 13.8 commanded voltage. Boom. Car is at a constant 13.5 volts now, and driving better. Originally I thought the problem had to be in the alternator wiring itself. I used 1 long run of 4 guage from the alternator all the way back onto the battery post that then runs into a kill switch. But since the alternator is charging the car “properly” I have since dismissed it. I’ve checked the wiring, grounds, and where it connects into the ecu, so I guess the ecu isn’t commanding the proper voltage to the alternator. Till I find out a solution would I harm anything with the alternator unplugged?
TSP stage 2 cam | aFe cai | Speed Engineering Long tube 1 7/8 catless headers | Self Ported TB | Circle d 245mm 4400 stall | ZL1 NPP Cat-back exhaust | 3.91 gears | Full BMR suspension/bushings |VMS drag pack 17x10, 17x4| Granatelli Motorsports pro stock spoiler| Heritage Grille | Zl1 Addons front bumper conversion kit | Whole lotta weight reduction
05-01-2024, 09:46 AM | #2 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
It won’t hurt it. It will just always charge at 13.7-13.8 and will have a fault. I have personal experience with this and my LS1 swapped Colorado.
05-05-2024, 06:18 PM | #3 |
Good to know it won’t hurt anything, thank you,did you ever find a fix?
05-22-2024, 08:39 PM | #4 |
Update***
(For anyone wanting the full 5th gen camaro gm service manual i have it linked to a google drive at the bottom of this post. DM me if having any troubles) Took a look at the service manual and was able to find some tests i can run on the 2 pin pigtail harness. long story short everything checks out good, good voltage/grounds. PWM on terminal 2 is operating properly etc. Still no charging when plugged in! I am going to get a new gm original alternator to see if my new alternator I got was bad from the beginning. if that doesn't work I can only suspect it is the BCM or PCM. kind of forgot at this in this 2 month long endeavor point If it is the computer, ill just live with the problem until this car is crazy enough to go holley Camaro service manual: https://drive.google.com/file/d/190l...ew?usp=sharing
05-23-2024, 12:52 AM | #5 | |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Request access or switch to an account with access rights. PS.Successfully loaded. Last edited by chevy pilot; 05-23-2024 at 11:17 AM. |
Today, 09:46 AM | #6 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Hi ,I don't have any experience with you issue sorry to say, but just wanted to say thx for the Manual download!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
