12-12-2019, 07:04 AM | #113 |
Drives: 2018 Camaro ZL1 Join Date: Dec 2017
12-13-2019, 07:02 AM | #114 |
Drives: 2019 ZL1 Join Date: Oct 2019
This is a good idea for sure! So basically buying Vette OEM C7 Z06 CCB discs and front pads and swapping the center rings and hardware from the OEM ZL1 discs over?
Do you have the factory torque specs and hardware pricing by chance for new bolts etc? Figuring these are torque to yield. That price is crazy good too. lowest I have seen C7 Z rotors for is $1309 plus shipping each, not to mention the $400-500 pads. Where is this at if you dont mind? |
02-24-2022, 04:57 PM | #115 |
Who Needs to KNOW?
Any chance of getting all broken product page links fixed @RacingBrake ?
ing for grip.
02-25-2022, 12:05 AM | #116 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
https://racingbrake.com/g6-2016/
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-21-2022, 10:15 PM | #117 |
Who Needs to KNOW?
Took the leap... I reused the hats off my ZLE rotors ( hats are aluminum for those curious ). Soaked them in evaporust or similar juice to take off any rust - and minimize cleanup and then user little scotch brite discs to remove any aluminum oxidation. Afterwards, hubs took nice shower in fluid film which should seal out any future moisture.
Rotors I used are from a Alfa Romeo Giulia/Stelvio - probably others out there with same size (390x36mm) - 100% OE match for ZLE rotor. I got them by mistake at a good price, so I was quick to check offset, hat size and spacing in case I needed to return them. The rest of hardware I reused and torque to spec applying proper locking juices where noted. Pads are from 2019 ZR1 - right around $500. Anyone need some spare temp sensors ? Yes - pad sits VERY close to the rotor hat, but that same on Z)6 ZR1 photos that I have seen online as well. Plan is to jig pads to a sheet of plywood and have local water jet shop zip off mm or two. Didn't pay to close attention to orientation of spring pieces, so they are all turned a bit - may go back and fix and retorque them next time I have the wheel off. How does that compare to regular OE parts brake job ZLE front rotors are about $400 , pads about $250 Comparatively speaking, this runs about $1600 more expensive. Worth it, probably not, but I wanted to TRY. And now that leaves me with a set of OE ZLE pads new in the box in the garage! D'OH PS. everything is brake dusty. PPS. If still considering it - get yourself new pins, spring clip and that bolt (pin?) in middle if available - just fewer things to clean.
ing for grip.
03-22-2022, 12:09 AM | #118 | |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
I'd just 'grind' the curvature of the pad a bit more, to free up clearance slightly. Other than that, looks fantastic! Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
03-22-2022, 07:26 AM | #119 |
Drives: 2020 Camaro ZL1 1 LE Join Date: Mar 2021
Nice work! I’m curious did you weigh the old parts vs new parts to see how much weight you saved? And I’m with Dave; I’d try a simple pencil grinder to clearance those pads. Should be easy to zip off a mm
03-22-2022, 08:13 AM | #120 | |
Who Needs to KNOW?
I should have, but I didn't. Should be about 14.xx lbs per corner less weight. As alternative to clearance pad, 4 1/2" angle grinder is about perfect size. I'll play with that idea later in the week.
ing for grip.
03-22-2022, 04:55 PM | #121 | |
Drives: 1LEs Join Date: May 2009
Vtor_ZL1, if you have not put the vented pistons in your front calipers yet (PN 19207043, one kit per front caliper), you will want to. If you track the CCM rotors much up front, you will trash your dust seals fairly quickly with the solid pistons (PN 19207044). |
03-23-2022, 11:52 AM | #122 |
Who Needs to KNOW?
Relevant part #, current as of March 2022. Collected from variety of sources ( verify before buying! some of the pad print info was captured from online product images - not always reliable!! ). Tried to keep spacing neat, but forum makes that difficult.
CCM Rotors . Corvette .. Gm...... AC Delco Years.... Size mm Inch .. 22805791 177-1120 2009-2013 394 x 36 15.51 x 1.42 .. 20981825 177-1175 2015-2019 394 x 36 .. 84307045 177-1251 2019 ZR1. 392 x 36 15.43 x 1.42 . Z28 .. 22958646 177-1164 Alfa Romeo CCM Components .. Front 6000626721 50546750 50546510 .. Front kit w pads 68371994AA -- list $8820 390 x 36 .. Brake pads 47.A992.61 GGA16 .. 47.A992.6200 GGA17 .. 17.A992 CGA 14 BRM0004GG 68372639AA -- not burnished .. Front pads (with burnish process): 68309171AA -- $1750 .. Front pads (without burnish process): 68372639AA -- $1150 GM Corvette CCB Brake Pads J57 option . Front Pad Thickness Manufacturer Printing .. 84345383 171-1235 .9.25 mm 2019 ZR1 9.25 mm 47.D0371.1 00 GGA18 .. 22956252 171-1010 10.29 mm 2009-2013 Z06, ZR1 24093 07.9408.51 (4W6) 094325 2392 TexTar T4300 FF A14 .. 23316708 171-1186 10.26 mm 2015-2019 Z06 24093 07.9408.51 (4W6) 461038 0762 Textar T4300 FF A16 .. 23198733 171-1142 10.26 mm 24093 07.9408.41 (4W6) 110623 2871 Textar T4300 FF A14 .. 23284028 171-1254 Z28 Brake Pads 10.26 mm 24093 07.9408.51 (4W6) 871568 0362 Textar T4300 FF A18 2018 Camaro ZL1 1LE Brake Rotor J6H .. 84271643 177-1247 390.2 x 36.1 15.36 x 1.42 Caliper Rebuild Kit .. 19207044 Solid Caliper Piston Seal Kit .. 19207043 Vented Caliper Pistons Seal Kit
ing for grip.
05-10-2022, 03:07 PM | #123 |
Who Needs to KNOW?
Last bit was to clearance brake pads relative to rotor hat. ZR1 pads are quite tall in this area and left around 1mm clearance. Original plan was to have local water jet shop trim off a bit and call it done. Got as far as building jig for pads but then could not align down time w time at water jet shop. It was messy, but angle grinder got it done, combo of grinding disc and clean up w flap wheel. Dab of POR15 made it looks as good as OEM (minus the runs!)
For reference, I took off about 4mm (2019 ZR1 CCM Pads) Love the initial bite of these pads and much lower dust vs OEM ZLE pads.
ing for grip.
