#113 | |
![]() Drives: 2021 Corvette Z51 Join Date: Dec 2014
#114 |
Drives: Mostly Stock Join Date: Jul 2012
Powdercoated steel was the best option for us. We wanted to be sure we would end up with a great price when this intake becomes available and aluminum was not the best choice for that. But that wasn't the only reason we sided with steel here. It won't affect performance at all - intake air temperatures will not be affected by the steel box and the weight gains will be very minimal. The added power will also make up for it!
#115 |
Wow, great job guys and thanks for all the info. I am looking forward to this.
#116 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
#117 |
Thanks for your input! The resuts will really depend on the type of testing we do and the conditions we do the testing in - if we are able to do it. The good news is that with our design, the filter is not a restriction in any way.
#118 |
![]() Drives: None Join Date: Feb 2016
Will your air box inlet be larger than stock? I know that the 5th gen benefitted from a larger than OEM air box opening in the bottom. Intakes like the Airaid were great except for the fact that they used the stock sized opening for the air box, and it bottlenecks before it even gets to the filter. I couldn't tell if anything was changed from looking at your renderings.
#119 | |
#120 |
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
The "Classic V8" intake sound made by the larger intake, at least on the video on my computer, to me, sounds more like "old beater" V8 sound. I prefer the OEM sound much more.
Sorry guys, itīs just my take on this. I hope you can find a way to improove it, and I will certainly buy one, once my Camaro is delivered. |
#121 | |
Mishimoto Camaro SS Performance Intake Development
I appreciate the response, but I'm actually talking about the air box inlet before the filter. The "air scoop", if you will, on the bottom side of the air box that the air first enters before any other part of the intake system. Edit: this part:
#122 | ||
![]() Hope this helps! |
#123 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I just read through your email on this and really want to thank you guys for not just pulling numbers out of your asses. This kind of communication...clean, simple, backup for your results is what I love to see. I'm definitely getting one.
I would just ask if you guys can include the option to add a second filter to the pre-sale offering. I like to have 2 on-hand, so I always have a clean one to pop on if the other is dirty. Thanks again guys.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
#124 |
Thank you. I guess we'll have to see if that OEM inlet is a restriction at some point.
#125 | |
This kit can only come with one filter, but that filter is actually pre-oiled, so it's reusable! Our filters will allow you to run several thousand miles before they need to be cleaned. However, you can certainly buy this 5 inch filter separately and directly from us! You're welcome! |
#126 |
