07-05-2013, 10:53 PM | #113 |
Drives: 2010 Camaro 2SSRS RJT L99 Join Date: Jun 2010
Thats FUNNY there!!!
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages. More to come!! |
07-05-2013, 11:15 PM | #114 | |
Drives: Dark Knight Join Date: Sep 2012
07-06-2013, 02:30 AM | #115 | |
Drives: 2015 2LT Torch Red C7 Stingray Join Date: Jul 2012
07-06-2013, 04:19 AM | #116 |
narrow tires on wide rims should be illegal. unsafe. Just like the idiots that make the back of the truck lower then the front. Just shows your stupidity. The rims make it look like you screwed up and bought the wrong tires and the trucks look like the springs are broken. And GM put the wrong size tires on the ZL1 that was at my dealer. the tires were narrower then the rims. just like in that pic. The badges thing. I put red SS badges on my 12 6.2l Silverado that I lowered put Sway bars LT headers and a supercharger on. I was going for a If GM made a 12 Silverado SS this would be it.
07-06-2013, 04:27 AM | #117 |
07-06-2013, 08:22 AM | #118 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
I wasn't going to be the first to mention the tire and wheel matter . . . or especially anything about "legality". But now that the door has been opened . . .
JC - The difficulty comes in establishing the boundary between that which is "acceptable" and that which is not. And you don't get to insert your own preferences and prejudices into it either; any law needs to remain neutral in that respect.). You may not like what the rear setup on the 1LE looks like, but it is entirely within the tire industry (Tire and Rim Association) guidelines for tire size vs wheel width. I don't happen to like the appearance of tires that are squeezed down onto rims closer to min-recommended than max. Does that mean I'm entitled to a law that would make an awful lot of OE tire/wheel packages, (including the SS) illegal? See what I mean? That said, the maximum and minimum "acceptable" rim widths for every tire size are at best recommendations. While I don't think that individual tire manufacturers are absolutely bound by those tables, there aren't very many tires that don't conform (there are a few). Fortunately, those max/min widths appear to be slightly conservative. IOW, the first half inch outside either the max or min widths does not change the setup from being perfectly safe to fail. Reality does not divide that sharply, unless you're standing at the edge of a cliff or at the end of the plank on a pirate ship. While it is not possible to determine the tire size shown in Post #1, it is possible for it to be too small in terms of load capacity. To clarify, I'm talking about what a 4000 lb car actually needs, not the oversize-overcapacity tires that Chevrolet has seen fit to put on these cars (likely with appearance reasons in mind). Check out JusticePete's thoughts on the matter of Camaro tire sizing if you don't want to take my word for it. Quote:
Just for illustration, the 626 tires (50 profile) are on wheels half an inch below max recommended, and there is a huge amount of tire distortion going on in a hard corner (right front tire at 37 psi is squashed and folded under and the sidewall bulge on the right rear has disappeared even though it was inflated to about 45 psi). By comparison, the Malibu, with much taller 60-series tires and relatively more of its weight on the rear tires but on wheels half an inch above max width, shows much less tire deformation, even at only 33 psi or so. Same driver (me), both cars being cornered to the point where the outside front tires are carrying very little weight. Norm Last edited by Norm Peterson; 07-06-2013 at 08:54 AM. |
