Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 06-29-2013, 09:44 AM   #113
transformer85
Drives: 2010 2LT Camaro
Dash and cupholder abl
I have been trying for months to find the abl light that goes on the dash panel and the cupholder, where did you find it?????
transformer85 is offline   Reply With Quote
Old 06-29-2013, 10:04 AM   #114
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
sjmautoprod sells them.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 06-29-2013, 10:22 AM   #115
transformer85
awesome thanks!
Old 07-16-2013, 01:41 AM   #116
snaphappy
snaphappy's Avatar
Drives: 2011 Camaro Convertible SS2/RS LS3
Looking at this diagram, I'd have to remove the radio, swap out ac vents, you name it, it's not just a matter of popping one dash out and putting the other on. I just keep trying to convince myself that I can do it! A video would be encouraging!
snaphappy is offline   Reply With Quote
Old 07-16-2013, 07:19 AM   #117
Eich
Drives: '11 SW/Beige 2SS RS Manual
I'm planning to do this at some point. When Ofer gets the MyLink retrofit finished, I might just tackle both at the same time.
I'm surprised that one of the many guys that added HUD to a 2010 hasn't done a video.
Eich is offline   Reply With Quote
Old 07-16-2013, 08:04 AM   #118
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
To do a Video is a lot of work, it takes 3 guys and it will be over 1 hr of video, dont think many will look at it.
2SSRS@Gen5diy is offline   Reply With Quote
Old 07-17-2013, 08:58 PM   #119
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Might not be too bad if we break it into parts video maybe
Remove center console power outlet, remove USB port aux input. Remove center console gauges, remove side panels, remove center console.
Remove trim on dash (ABL trim). Pull battery.
Pull out radio controls, pull out radio, pull a pillar trim. Remove gauge bezel, remove gauges, remove steering wheel trim, remove steering wheel.
Remove glove box, remove onstar module, remove onstar backup battery, unbolt airbag, remove center defroster vent, remove light sensor, unbolt dash.
Remove hood release, release diag connector, unclip fuse box, and remove the dash.
Once the dash is removed, then you can remove the center duct, cut the hole for the HUD switch and HUD if needed, then install HUD.
If we could break it into 3 15 minute videos, perhaps that would work.
The removal of the center console power adapter, and passenger airbag connector seemed to have given us the most fits. Figuring out how to remove the hood release and the fuse box was the other part that got us.
skuttduck is offline   Reply With Quote
Old 07-17-2013, 10:35 PM   #120
2SSRS@Gen5diy
Sounds like i have a lot of work to do, I dont remove the center console power adapter it comes out with the center console, PS skuttduck i will start with some of this soon when i do the MYlink.
Old 01-06-2014, 05:05 PM   #121
Sigmon
Drives: 2010 Camaro 2SS
I don't think we can post pricing here. But if you go to a site like gmpartsdirect.com or gmpartshouse.com and enter in the part numbers listed on the first page, it doesn't seem all that expensive really.
Sounds like you (and me) would need 4 total parts:
  1. 2012 DASH PART # (Dash only) #92242674
  2. Center outlet vent- #20965303
  3. Passenger leather insert with orange stching- #22880758
  4. Driver leather insert with orange stiching - #22838803
(or different part numbers for the driver/passenger insert depending on material and color preference)
Does anybody know what part numbers I need for the black leather dash inserts with light colored stitching I believe it is a white or grey. Thanks
Sigmon is offline   Reply With Quote
Old 06-08-2019, 09:20 AM   #122
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
I got a zl1 dash that came with eveything ( all the wiring hud, airbag controls etc.
I ordered a bunch of harnesses from gen5diy
Footwell
Hud
Abl
4 gauge pack.
but may have made a slight error as I ordered non zl1( my car is not a zl1) but am swapping in a zl1 dash. I know I have to reuse my DIC which I am ok with.
I've installed mylink in my old dash.
Which harnesses do I need to swap over?
The radio harness for sure since Ill be putting Mylink back in.
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 06-08-2019, 05:34 PM   #123
Pagliaro
Pagliaro's Avatar
Also no DIY listed instructions listed in this thread ( was linked from diy index. I did find some elsewhere and may write/video my process when I get to it.
