Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 11-25-2015, 04:40 PM   #1149
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
I know, these people are getting fast! But just imagine what you could run in some of that crazy negative DA.
And direct port meth injection huh... That's crazy, we're gonna have to start calling you Heisenberg
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 11-26-2015, 05:04 PM   #1150
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Nah, that would be my wife. She has offered to mix 50/50 water/methanol at home but I don't want to store pure methanol near our dogs. She can get water that is more pure than distilled, they use it for their gene therapy.
Went and started taping the holes for the methanol nozzles. Problem is that the runner wall is too thick for the AIS nozzles, I will have to drill a bigger hole just before the tap to get the 11mm part in.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 11-28-2015, 02:50 PM   #1151
MagnumForceGB
After doing some research, I went ahead and ordered a 3.125" pulley. This will max out the SCi, so if I want more power I have to go to the Si impeller. The Si will definitely make more boost but I think it needs more engine power to turn, it is mostly recommended for bigger V8's that have the torque.
I won't be installing it immediately, I have to get some more work done first. Most of it will be for engine safety since it will be pushing the limits hard. Should be interesting next year.
Old 12-02-2015, 01:57 PM   #1152
JantzenOKC
JantzenOKC's Avatar
Here's a cold air intake for you to go along with that badge.
3.6L Twin Turbo V6
10.75 @ 131mph
Old 12-03-2015, 05:27 PM   #1153
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I'd like to see ETMX183 do this with his nitrous setup. Looks like that is a pain in the ass drilling and tapping that? Was there not enough room to get it into the aluminum part, or did it just not make sense putting it there?
Old 12-03-2015, 10:17 PM   #1154
IPF Tuning
IPF Tuning's Avatar
Drives: Chevy - GMC - Cadillac - Buick
Hi
I'm excited for the supercharger install please send us pictures and video of the finished product. I'd love to get video of the big race with your wife. if you need any support please give me a call at 844.888.8863.
best regards
Dereck Phillips
IPF Tuning
IPF Tuning is offline   Reply With Quote
Old 12-04-2015, 08:36 AM   #1155
MagnumForceGB
The aluminum adapter is too low, the nozzles holders would have been hitting the valve covers. If I had a 1" spacer below the adapter that would work, but the runners would be too long.
It wasn't too hard to drill and tap, but the big pain was getting all the shavings out of the manifold since you can't open the top like the LLT one.
I'll take a picture of it sitting on the engine tonight, you can see how much room there is. It will be possible to fab a direct port nitrous setup since those nozzles can be longer. Would probably look bad-ass.
Originally Posted by IPF Tuning View Post
Hi
best regards
Dereck Phillips
IPF Tuning
I've had my supercharger installed, I'm the one running 11.84 in it. This mod I'm doing now is pushing everything to the limit, the SCi head unit at max rpm, 15 psi of boost on the LLT, safety measures for if the meth fails. I will see how fast a stock internal LLT can go or I will have an oil change on the track while doing over 100 mph.
For my wife's Mustang, we are working on her supercharger purchase. If she gets her promotion to Director of Biological Warfare then we should be good.
Old 12-04-2015, 09:39 PM   #1156
MagnumForceGB
Placed the manifold on top of the engine to show how much room there is. Yes the engine is dirty.
Old 12-05-2015, 11:10 AM   #1157
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
I'll leave this here for Jason.
etmx183 is offline   Reply With Quote
Old 12-05-2015, 11:12 AM   #1158
etmx183
etmx183's Avatar
More injection porn for Jason. LOL Don't blame me, not my idea.
Old 12-05-2015, 11:13 AM   #1159
etmx183
etmx183's Avatar
I'll blame it all on Derrick. :-)
Old 12-05-2015, 12:17 PM   #1160
JantzenOKC
JantzenOKC's Avatar
3.6L Twin Turbo V6
10.75 @ 131mph
Old 12-05-2015, 01:02 PM   #1161
MagnumForceGB
That nitrous setup looks good, next year is going to be interesting.
My 3.125" pulley on top of the stock IPF pulley. I bought a digital caliper and the stock IPF pulley is 3.80", the size I thought it was.
I also got a Greddy FV BOV. The FV is Floating Valve, when the intake manifold is under vacuum the BOV isn't open unless there is boost pressure inside the charge pipes, so no air will get in through it. The bypass valve won't work anymore, too much air needing to be moved.
I also ordered a new V3 vent and dipstick plug so I can replace the worn out brass ones I have. Still seeing what else I need to work on, but going to be an awesome setup when I'm done.
Old 12-07-2015, 06:46 PM   #1162
MagnumForceGB
Finally got the 3.125" pulley installed, hate doing pulley swaps. I originally got a 104.5" goodyear belt for it but it was too short so I had to go back to the 105.5" belt I had for the 3.33" pulley. The tensioner mark is at the halfway mark so I should be good.
I got the cold side pipes mocked up, just have to get everything installed now. Going to lower my RPM limit to 6500 for now just to get everything tuned right. Also going to see if there is a place to install a wastegate for a torque booster setup, allow some others to feel high torque without having to use meth to keep the engine alive.
