04-30-2024, 02:58 AM | #1107 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Batteries replaced.
04-30-2024, 07:28 PM | #1108 | |
04-30-2024, 08:51 PM | #1109 | |
David Vianu
2010 Synergy Green 1LT Last edited by 2010sgm; 05-01-2024 at 04:24 AM. |
04-30-2024, 10:43 PM | #1110 |
05-01-2024, 07:11 AM | #1111 | |
Drives: 2010 Camaro Join Date: Dec 2022
I had to transfer same grill between bumpers and its not fun, but yea yours aint in all the way. Its absolutely a pain. A real fun thing is getting it put on all the way and then having it pushed back out over 120mph. I had to install these shark teeth clips on the back of those tabs to stop that from happening. Good luck with it. Car looks great otherwise.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
05-01-2024, 08:42 AM | #1112 |
Yeah, it is quite the PITA!!! Hope you can get it adjusted. Car looks great.
05-03-2024, 03:25 AM | #1113 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Late night oil change. Weather was nice, I had all of the stuff so I said WTF, might as well get something accomplished.
05-03-2024, 06:17 PM | #1114 | |
"Cam Only"
Only drawback is starting the car and pulling back into the garage late at night which my neighbors likely don't enjoy as much as I do.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
05-06-2024, 07:58 AM | #1115 |
Got the 2" ARH longtubes with high flow cats, 3" stainless exhaust with x-pipe to the factory npp mufflers done this weekend. Sounds great, just have to finish my ported TB and get a nice tune done, can't wait!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
05-06-2024, 11:19 AM | #1116 |
Drives: 2010 Synergy Camaro Join Date: Apr 2023
I stared at the chipped windshield that I'm going to have to replace after a local firetruck kicked up a rock and launched it at me.
Odd, I thought that everyone had to follow the "must have mudflaps" rule. |
05-06-2024, 11:22 AM | #1117 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
That sucks though... do you also need a blend door replacement? Would be a great time to do it if you do. I'm a glass half full type of guy though.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
05-06-2024, 11:23 AM | #1118 | |
Anthony S
05-06-2024, 11:30 AM | #1119 |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
Awesome NoDak!!!!!
416ci LS3/Vortech V7/Built 6L80
994.4 RWHP 793.8 RWTQ |
05-06-2024, 11:50 AM | #1120 | |
2014 1LE - Sold
