07-29-2017, 01:17 PM | #99 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
07-29-2017, 01:31 PM | #100 |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
07-29-2017, 01:58 PM | #101 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Fogging windshield
I never could get it lower than 78 before without extreme fogging. So far today 70 degrees, fan turned up, with no fogging and it's rained as well. Very humid day.
07-29-2017, 02:38 PM | #102 |
Drives: Black Camaro SS 1LE Join Date: Feb 2017
Anyone in the Washington D.C. area have this issue fixed? When I went in for an oil change at Koons Tysons Chevy (which had to be done twice because the tech used the dealer oil instead of the Dexos 2 oil I supplied) The sales rep acknowledged the fogging as a normal occurrence on most of the Camaros and just told me to turn the air up, which I was already doing as well as shoving a rag on my dash. Needless to say I'm looking for another dealer that acknowledges this as an issue and has fixed other Camaro's.
07-30-2017, 12:25 AM | #103 | |
Drives: X-15 Velocipede Join Date: Mar 2008
Some weren't so lucky. They put it all back together, new windshield and all, and the defrost vents were leaking almost as bad as before repair. Anyone having this done should communicate to service to check for leaking air after repair, but BEFORE windshield reinstalled. If it's still leaking, they need to leave the windshield out and continue diagnosis and repair until very little air leaks out the defroster. Check the repair when picking the vehicle up from service. Simply feel for the air with your hand.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
07-30-2017, 08:44 AM | #104 | |
Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
07-30-2017, 11:23 AM | #105 | |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
This will be my fix! Could you link the black drawer rubber part you used & how did you cut it so perfectly shaped?? Sent from my iPhone using Tapatalk
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
07-31-2017, 07:35 AM | #106 | |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
Link to Harbor frieght drawer liner: https://www.harborfreight.com/solid-...ner-65565.html As for how I cut out the shape, I just took a couple sheets of printer paper and taped them together (it's about 14-15" wide) and layed it up on the dash flush with the base of the wind shield. Held it in place with one hand and pressed down on the paper around the perimeter edge to make an impression on the paper. Took it out and cut around the impression and that's the shape I got. I did put it back up there to make sure it was what I wanted before I transferred the shape to the rubber mat. I tried to just trace the outside outline of the pattern onto the smoother side of the mat before I cut it but the permanent marker I used was too dark, black marker on a black mat doesn't show up so well. So I put some blue painters tape on the mat and then traced over that. Works much better when you can see the line you're trying to cut. All of it took about 15-20 minutes, really pretty easy to do. My wife was wondering WTH I was doing the whole time, she hadn't been in the car when the condensation problem was really bad.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
07-31-2017, 07:41 AM | #107 |
HA HA, I hadn't read through this whole thread before I posted up the piece I made so I hadn't seen Currs post and the similar cover he made. Wasn't a copycat thing Curr, I just noticed it this morning.
2017 2LS 1LE
08-01-2017, 12:22 PM | #108 |
Drives: '17 2SS 50th Join Date: Sep 2016
I set my vent settings to cabin & footwell all the time and I do not have this problem other than a few days when it's extremely hot and humid.
Even those times I have a very slight condensation towards the bottom of the windshield. Nothing that could be considered an issue. Why is it that some owners have a more severe fogging than others?
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
08-01-2017, 12:25 PM | #109 |
I have tinted(very light) windshield btw, if that makes any difference.
08-01-2017, 12:25 PM | #110 | |
My thoughts on why different.... Different regions so different humidity levels. Different climate control settings. Some like it colder than others. And the sad fact, anything mass produced will have tolerance variances making them all the same yet not. Sent from my iPhone using Tapatalk
08-01-2017, 12:29 PM | #111 |
If it helps people I don't care who copies that. I got the idea from someone else who used some material from Lowe's. I just happened to read the post they made, and looked at a black mouse pad I had laying on my desk. Figured Amazon or eBay would have something under "oversize black mousepad".
08-01-2017, 12:48 PM | #112 | |
I literally was in the market for one for my new PC! I'll just order 2 instead of 1. Sent from my iPhone using Tapatalk
