06-08-2012, 11:46 PM | #99 |
I haz camaro again :)
Drives: 2010 Chevrolet Camaro 1SS Join Date: Mar 2009
ugh, a 4 page arguement over a throttle body spacer, g'lord. lol.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd) 2010 camaro1ss(sold, missed, will have another someday) |
06-08-2012, 11:50 PM | #100 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
06-09-2012, 06:38 AM | #101 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
How about we all agree to keep quiet as to whether the super wedge works or not until we actually have them on our cars.
06-09-2012, 06:50 AM | #102 | |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Anyone, other than those with them, is only guessing anyway.
She is only memory now. |
06-09-2012, 07:09 AM | #103 |
Drives: 2012 AGM 2SS Join Date: Feb 2012
When a wing cuts thru the air the upper portion of the wing surface creates lift by making a negative pressure zone just above the wing surface. The throttle body blade in the camaro is doing pretty much the same thing and creating a negative pressure zone above it. This negative pressure zone can create a slowing down of the intake air and restrict your intake flow. It makes perfect sense that if you turn the blade flat that the restriction will diminish and you will get better flow.
06-09-2012, 07:50 AM | #104 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
^^^^^^LMAO^^^^^^
And you know this because you already seen this in the "wind tunnel"?! Are air speeds in the intake that high? Really? Negative lift hu? Yea ok.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-09-2012, 07:52 AM | #105 |
No not negative lift. Negative pressure. You appear to know absolutely nothing about this intake system or about fluid dynamics at all so please, please quit posting. Your dragging us down.
06-09-2012, 07:57 AM | #106 |
V8 Lounge member #2
And what proof do you have this is what is happening inside these intakes or are you just guessing?
06-09-2012, 08:03 AM | #107 |
06-09-2012, 08:21 AM | #108 | |
I will get some more data soon and its up to you if you trust it or not.( form a independent shop) |
06-09-2012, 08:29 AM | #109 |
At least you are providing something of substance
06-09-2012, 08:34 AM | #110 |
06-09-2012, 08:49 AM | #111 |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
what im thinking:
yes the blade will now be closer to 90* angle.. increasing airflow around the butterfly... but now that youre tilting the whole thing, youre reducing airflow at the top and bottom of the throttle body, because now that angle will be off, while the butterfly is straight the before and after in my head would be more like this to me... could be wrong? excuse my poor demonstration, but bored at work lol heres what I mean... now, after this change, yes, the butterfly is straight through, but the TB as a whole isnt... My thoughts are that the restriction you will get at the top of the opening, will actually offset these gains?? again, this is my thinking.. however, when its proven, I will be in for one as well I did not move the card and the cup for these pics... just changed the angle of my hand before: butterfly at an angle, but TB as a whole straight through After: butterfly straight through, TB at an angle Last edited by BronxxBombers213; 06-09-2012 at 09:56 AM. |
06-09-2012, 08:56 AM | #112 | |
She is only memory now. Last edited by IndeedSS1; 06-09-2012 at 09:06 AM. |
