dave@hennessey
Old 09-28-2013, 01:42 PM   #995
CAMARO_SS_2012
CAMARO_SS_2012's Avatar
Drives: 2012 Camaro 2SS
Someone here mentioned saying the command "Voice" to bring up Siri on my bluetooth... I've been using it often now with my new iPhone, very convenient!
I could also just hold the home button down for 2 seconds, but where's the fun in that
2012 2SSRS Camaro Ashen Grey Metallic
CAMARO_SS_2012 is offline   Reply With Quote
Old 09-28-2013, 03:58 PM   #996
scoticus.rex
LTC, USA
scoticus.rex's Avatar
Drives: Hobbes - 2013 Camaro 2SS RS M6
Originally Posted by SSizzle View Post
Remote start will not start the car if your check engine light is on. Also if you start it with remote start and open your hood, it will shut the car off. You can turn the car off by pressing the remote start button as well. Remote start shuts off after 10 min and can be restarted for an additional 10 min after that. After 2 cycles you must put the key in it to reset the system.
LOL... I discovered the opening the hood cutoff with remote start just yesterday.
scoticus.rex is offline   Reply With Quote
Old 09-28-2013, 05:46 PM   #997
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Works the same on my android phone. But I heard they changed it after 2012, so it doesn't work that way for model year '13 and newer.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 09-28-2013, 11:00 PM   #998
JEBariffic
JEBariffic's Avatar
Drives: 2011 Camaro SS
Maybe I'm doing something wrong, but when trying to make a call over bluetooth connection to my iphone, I say the voice command "call", then a name from my contacts, but it tries to dial a number instead and won't recognize the name. The work around is to say the command "Bluetooth" then "voice" which will then pass thru your voice commands to your iphone. It will then recognize names from address book and, in theory though I've not tried, also take voice commands for music playback.
JEBariffic is offline   Reply With Quote
Old 09-29-2013, 12:43 AM   #999
CAMARO_SS_2012
You need to set up a nametag for each number. Once set up, you can simply press the voice button and say "Call Home". It will recognized the nametag "Home" and dial the number immediately.
To set up nametags:
1) Press the voice button
2) A menu will pop up on the radio display. Select "Hands-free Calling"
3) Select "Directory"
4) Select "Store"
5) Say the entire phone number
6) Say the nametag
It's a bit time consuming to set it all up. I stored only the top 10 phone numbers I dial. But once set up, it's a lot faster than going through Siri. Be sure to come up with different names if the nametags sound similar, otherwise the car will have trouble differentiating them.
Also, if you have a iPhone 4s or higher, you don't have to say "Bluetooth"... you can go straight to Siri if you say "Voice" from the beginning.
Old 09-29-2013, 02:37 PM   #1000
911medic
911medic's Avatar
To set up nametags:
4) Select "Store"
6) Say the nametag
Wow. That seems like a lot of work. Not sure if the iPhone is completely different, but on my GS3, all I have to do, once the phone is connected via Bluetooth, is:
Press the call button on the steering wheel
After the car says, "Ready" and beeps, I say "voice"
The car opens voice commands on my phone (similar to Siri), and beeps
I say "Call xxxxxx, mobile" and the phone calls the mobile (or home, or work, or whatever I say) number of that person.
Done. I press one button, say a few words, and the call is made. No setup required, beyond my phone's contact list.
Old 09-29-2013, 04:42 PM   #1001
CAMARO_SS_2012
Yeah, like I mentioned, you can use Siri or this method, whatever suits you. The previous poster was asking why saying "Call XXX" did not directly dial the number and this is the reason why.
Set up doesn't take long, but I also use Siri for my non-stored numbers.
Old 09-29-2013, 09:36 PM   #1002
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
Originally Posted by VTXrider View Post
The first pull of the handle unlocks the door, the second pull opens the door. This is pretty common to a lot of cars.
My first car (BMW 3 series) was the first car with this, but the way it was designed was later made illegal because their way involved no mechanical parts, so in the case where electrical systems failed (like driving into water or something) the doors were impossible to open. Nevertheless I love the double handle pull, was very happy when I discovered the Camaro had it as well.
I think my favorite thing is the extra circuit in the driver side fuse box in the v6 for adding lighting etc, and the firewall pass through so i dont have to drill anything .
Also another tip, if you are using an iphone as a gps on google maps app, and listening to your tunes through the phone / headphone jack, google maps will actually dim the music down and direct you where to go through the car stereo, almost like having onboard gps!
SnowyCamaro is offline   Reply With Quote
Old 09-29-2013, 09:42 PM   #1003
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
Originally Posted by 1chasingspeed View Post
They just go through the functions from the radio to xm satelite radio, which I don't subscribe to, so pretty much a useless function on my car. UGGGHHHH!!!!!!
Pressing the wheel changes the band you're listening to. Rotating it up or down changes the stations within that band (or goes to previous / next song if on iPod).
Squillo is offline   Reply With Quote
Old 09-29-2013, 10:56 PM   #1004
Mr pogo
Drives: 96 Imp SS, 13 Camaro 2SS AGM
this works on bluetooth also.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=71668&dateline=136924  9466
Mr pogo is offline   Reply With Quote
Old 09-30-2013, 07:16 AM   #1005
JEBariffic
JEBariffic's Avatar
Thanks for taking the time, CAMERO_SS. Not a difficult process for a couple top numbers. And maybe some that were deemed unworthy enough to ride in the car might get the consolation of being worthy enough for a speed dial setup.
Old 09-30-2013, 09:04 AM   #1006
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
If you constantly drive 20mph over the speed limit your rear window will sometimes be filled with flashing lights, either Blue, Red, or even Blue and red at the same time.
The Bird is the word!
Old 10-01-2013, 12:55 AM   #1007
CAMARO_SS_2012
Old 10-01-2013, 07:07 AM   #1008
JEBariffic
JEBariffic's Avatar
Would more speed reduce that undesired effect?
The Radar / Laser MEGA thread raqball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 116 01-28-2017 11:04 PM
Color thread suggestions?? ArcAngel Site Related Announcements / Suggestions / Feedback / Questions 2 01-26-2009 11:08 AM
Funny story thread! MLL67RSSS Off-topic Discussions 0 12-04-2008 07:11 AM
Changing Photoshop Thread Format headpunter Site Related Announcements / Suggestions / Feedback / Questions 20 11-06-2008 05:40 PM
Its all about the little things... Roflmao 5th Gen Camaro SS LS LT General Discussions 30 03-02-2008 10:02 AM
