07-26-2017, 04:32 PM | #85 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Windshield fogging
Meanwhile driving my old Chevy truck ac wide open comfortable as a mofo without any fogging whatsoever. I wish people would realize this is not something we're doing or not doing as in running down to vatozone for some rain X fog X or simply turning our ac up to barely below outside temperatures. This is a physical defect in some of our cars.
07-26-2017, 09:21 PM | #86 |
Drives: 2016 Camaro SS Join Date: Jul 2016
Yep. It's a defect. Plain and simple.
07-27-2017, 12:26 AM | #87 | |
Tampa Bay Camaros
Drives: '16 Hyper Blue 1LT Join Date: Jul 2016
I had already lost 6 weeks when I first got it (this time last year) due to HVAC issues, I'd rather them not rip off my windshield and dash (again) if it's futile. I'm glad I have my 2000 Wrangler to use as my primary vehicle in the summertime. Funny how the 17 year old vehicle's AC works right but the new one doesn't...
2016 Camaro 1LT | V6 | A8 | Hyper Blue
07-27-2017, 05:26 AM | #88 | |
Fogging windshield
07-28-2017, 10:02 AM | #89 |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
This is pretty annoying, I also live in Florida and it's pretty bad in the AM, particularly when I drive across the Indian River every morning. So last week I remembered the microfiber rag I keep in the door pocket, I folded it in half and put it up on the dash to see if it would help.
It definitely did, except it didn't reach all the way across the vent, it was only a 12" rag. So there would still be a small bit of condensation on either end, wasn't really that bad. It would also slide off whenever I would go around a turn with any enthusiasm, so it would frequently slide around. I started thinking about using a piece of Kydex cut to the outline and setting it up there until I noticed some scrap pieces of rubber drawer liner laying around one of our shops here at work. Figured that would conform to the contours better so I picked up a piece of that. Made a paper outline and the scrap piece I had was just big enough to make two of them. This is what it came out like. Here's a vid I took after I got to work this AM. I added a small piece of gaffer tape to it to make it easier to grab. https://youtu.be/0IgCMYCtG6o I've had it on there for the past two days and have seen ZERO condensation build up so far. Yes, I know it's not a proper fix but I'm not exactly ready for a tech (even the one I trust completely) to have my windshield R&R'd.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
07-28-2017, 11:42 AM | #90 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
I suppose but I'd rather not have to resort to towels or some other makeshift repair for what is clearly a defect considering the price of the car.
07-28-2017, 11:51 AM | #91 | |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
Awesome! I need to stop being lazy and do the same. Sent from my iPhone using Tapatalk
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
07-28-2017, 11:54 AM | #92 | |
I can see your point. But if I knew the windshield issue going into it, I didn't at the time, I would still buy my Camaro. Sent from my iPhone using Tapatalk
07-28-2017, 05:45 PM | #93 |
Windshield fogging
UPDATE
Here is a write up of my car's situation and the service bulletin performed. It took 2 weeks to complete. Mainly due to the windshield having to be ordered from GM then drop shipped from the supplier to the dealership. Then installation and verification of proper install after 24-48 hours. The windshield has a molding on it when new and can be difficult to remove. Supposedly mine was cracked when removing it. An aftermarket windshield could be used but I was told it would appear different. They said they wanted to return my car as I bought it. They also have to schedule a glass company to do the glass work which adds time to the process. The main thing I noticed was an improvement. I left work then went by to get my car. The humidity was very high as when this problem is usually at it's worst. It literally rained right as I left work most of the way to the dealership. When I got in the car I immediately put the AC to the low setting and fan speed on high. I idled for about 30 minutes without condensation. I then came home and sat in my driveway idling another 30 minutes leaving the ac set to max. After an hour or so there were 2 small quarter to silver dollar sized condensation marks on the outside of the windshield but they are small. I see a major improvement after having this TSB completed. Before it didn't matter how high I turned the AC up to or how low the fan speed was. It was immediately like 2 pizzas splattered on the windshield. They showed me the 2 foam pieces that blocked the mode actuator door from closing completely. They removed them with a tool the technician made himself. My car has all the updated HVAC software as well. Overall they were very careful with my car and did their best per the bulletin to correct this issue. They promised to do everything they could to solve this issue. While there still is leakage it isn't so awful as before to where myself and my wife were totally miserable driving the car. I can run the AC in the low to mid 70 degrees now and not sweat to death without my windshield being plastered with condensation.
07-28-2017, 06:10 PM | #94 | |
Thank you for the very detailed update. You seem to be one of the very few who have had any success with this TSB. Did they use the new factory calibration for the blend door or the old calibration for the blend door? Sent from my iPhone using Tapatalk
07-28-2017, 06:24 PM | #95 |
Windshield fogging
This is the 3rd time my car has been there for the fogging windshield issue. First was an inspection for all controls and functions. Second was for a software update. This last time was for the actual TSB. The paperwork says technician scanned vehicle for up to date calibration software which the vehicle has according to their technicians.
07-29-2017, 09:05 AM | #96 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
Not taking mine in until they have a fix that really fixes. Their fix does not fix. My fix so far has been setting my AC at about 70 or 71 deg. So far no fog and 70 gets it pretty cool on a hot day.
07-29-2017, 09:17 AM | #97 | |
07-29-2017, 09:20 AM | #98 |
This is good to hear.
