Old 05-17-2017, 07:28 PM   #85
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
aa406079 is offline   Reply With Quote
Old 07-03-2017, 08:02 PM   #86
SpeedLimit
Drives: 2019 F150
Originally Posted by aa406079 View Post
Heres a visual update on my ongoing mods...
ALP 5 x head laser jammer installed... Seems to be working well.. ( needs cosmetic finishng)
Valentine 1 detector hardwired ( already saved me two tickets)
Curb alert and front camera installed ( aural alert works great)
Got it set up perfectly... didn't go off for this curb and I cleared it
Black exhaust tips installed and muffler painted black
NPP fuse ( best 5 min reversible mod u can do on the M6)
Phone mount ( clipmount)
Finally enjoying the car now that all that's left is the seats and some trim mods for the next 12-18 months...
Fine looking commuter and weight savings ideas... quick moving transportation.
Let us know what you think of the ALP system.
SpeedLimit is offline   Reply With Quote
Old 08-23-2017, 02:22 PM   #87
aa406079
Interior Updates
firstly......A big shout out and F#*K YOU to photobucket for trying to charge me $400 a year to share images....\
Onto the weight savings....
removed the rear seatbacks.... 18.5 lbs
used wetsuit material and a good fabricator to have this made...
https://drive.google.com/open?id=0Bw...lEwS2l1aHpuc2c
only weighs 2.05 lbs
total savings 16.5 lbs.... I will probably have the seat bottoms removed since I expected the seatback to weigh closer to 25 lbs...
Also added some bolstering to soften the armrest and match it to seats....
Old 08-23-2017, 03:49 PM   #88
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Im guessing you have the airbag light on. You going to try to find a fix? Ive been doing a lot of digging and the passenger side is a real problem.
BTW awesome build. Best of luck.
WhiteNight is offline   Reply With Quote
Old 08-23-2017, 07:26 PM   #89
aa406079
Honestly I never notice it.... I run the HUD with full info...the only time I ever look down at the gauges is for a fuel range check or an alert pop up... The HUD is a wonderful thing...
Old 09-01-2017, 03:58 AM   #90
aa406079
So.... one thing I know is my mind works best in the middle of the night....
As you know, I'm seriously considering an engine build in the next year or so to get me a st above 500 RWHP... or roughly 565-575 at the crank...
Now... the last thing I want to do is create a car that can't handle its power... so my mind has been storming... going over downforce numbers....
The ultimate form of this car may just be a street legal version of the GT.4R
" GT4" ?
Stay tuned....
Old 09-01-2017, 10:07 AM   #91
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
For sure the 1LE can handle the power. It's the same suspension as the ZL1, and that has no trouble staying composed at and past 650HP, even with the added front weight handicap.
I'm right there with you; a GT4 street car will also be a formidable track-day weapon.
Old 09-07-2017, 12:17 PM   #92
slick3
Drives: Garnet Red - 20 ZLE
If you do any Aero what so ever, I would stick with the ZL1 1LE aero setup. Its the only thing proven and balanced correctly that you are going to be able to purchase off the shelf. The rest of the stuff may look cool and fit, but what are you really buying into? If anyone gets my money its going to be aero components that are wind-tunnel tested, chevy engineer approved and made specifically for this car. ZL1 1LE all the way. Unless of course you are some aerospace engineer who understands what the hell he is doing.
slick3 is offline   Reply With Quote
Old 10-13-2017, 11:54 AM   #93
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Originally Posted by rorymick View Post
At first I loved where you were going with this one...
But given the extensive work you wanna do. Why not just order a 1ss? And aftermarket the hell out of it.
RORYMICK That yellow camaro your using as profile pic is mine... well its my wifes why u got it? No biggie...
Old 10-13-2017, 01:28 PM   #94
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
You do known that the light represents that NONE of your airbags are working, not just the disconnected ones.
Old 12-08-2017, 10:53 AM   #95
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
I looked into this when I had my Sparco seats in.. the only way this can be done is to test the impedance from the OEM seat harness and then putting resistors in place of it.
The bladder will have to be taken from the OEM seats as well and then put in the racing seats. Yes, it's a hassle however I had a proper harness setup so in the case of a collision I would depend on the harness instead of the airbags.
Without a harness bar/cage setup, it would be dangerous since the airbags are inoperable.
Richard0nee is offline   Reply With Quote
Old 06-12-2018, 09:18 PM   #96
aa406079
ZL1 1LE Wheel and tire package ( summer DD)
so.... I did a thing the other week....
https://drive.google.com/file/d/1E1q...ew?usp=sharing
Considering my car weighs about 200 lbs less than a ZL1 1LE... I went slightly smaller on the rubber while matching the ZL1 1LE wheels size of 11" wide on the front and 12" wide on the rear all in 19" diameter
Michelin Pilot 4s in 295/30 front and 305/30 rear ( might go to 315 next go)
I wanted a good amount of sidewall preloading as I really noticed how sharp the turn in was with the winter PA4's 285's which had a narrower width than the original PSS's 285's.
I will post up the weights next week when they're delivered right before mounting.
BC Forged RZ23's ( 19" x 11", 19" x 12") should weigh about 24 lbs or so...
They're also knurled on the inside like the Z28 had to increase grip on the tire at high G loads... At this point the car is ready to accept the power additions I am planning in Spring 2019.
Will probably go with the Kaizenspeed 565N package and perhaps go for a lighter exhaust option like MBRP with long tubes so I can shed a further 40 lbs and get myself close to 3600 lbs with a full tank of gas and 500+hp at the rear wheels...
Thanks again to Paul at PK Auto Design for another great set of aluminum forged one piece lightweight custom wheels.
Old 11-22-2018, 10:30 PM   #97
stook2001
Drives: 99 M3, 04 STi, 16 2SS
Any pics of the BC Forged wheels on your car? Very nice! Thinking about a vaguely reminiscent style for my car - the VS Forged VS14. Similar spoke detail, although more spokes. Incidentally, I also like your VS03s. I stumbled upon the image of your car on the lift with those wheels via Google Image search not realizing that you were on the forums.
stook2001 is offline   Reply With Quote
Old 04-16-2019, 01:07 PM   #98
aa406079
sorry , been busy with life for a long while... here ya go
