01-07-2021, 09:44 PM | #85 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Well I can say they claimed to have fixed the window delamination on the 2020 cars and mine delaminated. So even if "they did", they might not have.
01-08-2021, 07:37 AM | #86 | ||
If either of you start experiencing hot start issues - at least adding a ground wire is an easy and cheap fix.
01-09-2021, 12:52 PM | #87 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
All,
Went over to the storage unit today to let her blood circulate a bit and looked at where/how long to best put a cable. Using FX's water pump bolt idea, there's a nice path depicted in the photo here. Keeps the cable away from all the belts and hoses and would lay nicely right around the fusebox. 30" hole-to-hole will do it. There's enough space to lay the cable under the POS and all the other cables too, making it look more like it belongs there.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes Last edited by TP2SS; 01-10-2021 at 03:53 PM. |
01-09-2021, 04:07 PM | #88 | |
Drives: 2016 2SS M6 Join Date: Feb 2011
2016 SS M6
01-09-2021, 04:36 PM | #89 | |
See post #71 for an alternate location that uses a bolt location on the water pump.
01-09-2021, 05:10 PM | #90 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Thanks. I did it this way after seeing your post. The cable they sent me was only a little over 19 inches and wouldn't have reached the idler pulley bolt. Worked great.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
01-10-2021, 03:48 PM | #91 |
Drives: 2016 Camaro 1SS Join Date: Aug 2016
There are several ways you can route the ground cable. I routed mine under the fuse box so that less of the cable is visible.
01-10-2021, 09:47 PM | #92 |
Drives: 2016 Camaro SS Join Date: May 2016
Sorry if this is a dumb question, but do you have to disconnect the battery? Also, if one end is connected to a bolt where the tensioner is, how do you connect the other side? Sorry, I’m a complete noob at this but have had this same exact issue with my SS since 2016.
01-11-2021, 06:55 AM | #93 | |
And no - you do not need to disconnect the battery.
01-11-2021, 09:30 AM | #94 | |
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
01-11-2021, 11:00 AM | #95 |
Nice work! Your photo editing skills far exceed mine!
Thank you for taking the time. BTW - my beastie is hyperblue with silver rally stripes too.
01-11-2021, 12:01 PM | #96 | |
Not sure what the incidence of this problem is. I don't have any symptoms yet. But nice to see members putting their brains to work! |
01-11-2021, 02:45 PM | #97 |
I just wanted to thank you all for your help. My 2016 SS had given me this hard start up problem ever since 2016. Magically, every time I went to the dealer it would start up right away. Today after installing the cable (I went the route of installing it to the water pump bolt) I took it for a 20 minute drive and drove it really hard. Put heat in the engine, came home, left it off for about 10 minutes and cranked it back up (palms were extremely sweaty at this point) and BAM!!! It started right up!!!! I would have NEVER tried this EVER if I didn’t know about this little cheat code! Hahaha! Thank you everyone!
01-11-2021, 03:15 PM | #98 |
I'll play...here’s what I did on mine.
