11-19-2022, 07:27 AM | #85 | |
FWIW GForce had the rep as a go to for one piece DS along with DSS but don’t offer them anymore on their website. I asked why and was told by their sales mgr they were dropped from their product line because of supply chain issues …hmmm? |
11-19-2022, 07:39 AM | #86 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
G Force and DSS I believe we're more popular because of marketing, when I first started look they were the only ones that people talked about or came up In a search. Aftera bit of research I came up with these other companies. To be fair DSS probably has more 5th Gen shafts out there then anyone else so you will hear more issues with them because of that.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
11-24-2022, 08:03 PM | #87 |
GulfCoast Driveshafts is running a BF special $125 off aluminum driveshafts through Monday.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
11-24-2022, 08:20 PM | #88 |
Go figure lol
11-25-2022, 04:03 AM | #89 |
Drives: 2010 camaro ss Join Date: Aug 2021
Of course they did!! Oh well
Sent from my iPhone using Tapatalk |
11-25-2022, 07:05 AM | #90 |
Will it fit length wize from the trunk to the front with the rear seat down without getting in the way of the shifter so I can take it to get it installed?
11-26-2022, 06:55 AM | #91 | |
11-26-2022, 07:23 AM | #92 | |
As far as speed bumps go, the diff and driveshaft do not move with the suspension at all. So I havent noticed any issues at all with that.
11-26-2022, 07:40 AM | #93 |
Gulf coast doesn't require any measurements just order it for your vehicle. Mines on the shelf as well and I'll install when I am working on something in that area or I get bored.
11-26-2022, 09:21 AM | #94 |
Thanks for the replies guys, much appreciated!
11-26-2022, 09:06 PM | #95 |
11-27-2022, 08:50 AM | #96 |
When you get a chance could you measure the length of the DS. I’d like to know so I can determine if it would fit length wize from the trunk to the front with the rear seat down without getting in the way of the shifter, so I’ll know if I’ll be able to take it in my car to get it installed or to have it shipped to the installer when I order it. Thanks in advance.
11-27-2022, 08:52 AM | #97 |
I'll measure it for you but I am 99.9 % sure it'll fit. I'll try to do it tomorrow.
11-27-2022, 09:22 AM | #98 |
Thanks, much appreciated!
