05-02-2022, 11:17 AM | #71 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I'm just bummed. I thought I made a pretty good joke on page 1, but after 4 more page...nothing.
05-02-2022, 11:27 AM | #72 |
Petro-sexual
One of our cars has the standard EE-can, and it does great. I think we get about a tea spoon to table spoon out every oil change (which is probably about every 700-miles). I just pulled the lid off, and it was pretty dang clean, like seen in the video. There was little to no puddling anywhere.
I think any and all these cans are worth at least something. That MM might be better for bigger power cars, but I think I have what suits my build and plans.
05-02-2022, 11:54 AM | #73 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
the MM just seems illegal with a vent to atmos on road or on a track. id be shocked if it passed race inspection. the other looking sealed up just seems better.
05-02-2022, 12:09 PM | #74 | |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Elite filters and vents back to the intake (closed loop) which is how most catch can systems work Extremely well documented problem with DI engines. Savagegeese (and others) have videos on it |
05-02-2022, 01:10 PM | #75 | |
Drives: 2019 ZL1 Join Date: Mar 2019
“ Tampering with emission systems causing a rise in crankcase pressure” Basically blaming it for damaging the ring pack. So now he’s fighting with corporate on it. He should of took it off yes, but point here is even for dumb stuff like this they can deny a claim. So now his attorney has written in asking to show proof how this damaged his ring seal(s). Burden is on them.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-02-2022, 01:32 PM | #76 |
Crazy - vents to intake and it's a relatively low air flow
05-02-2022, 01:44 PM | #77 |
Drives: HBM ZLE Join Date: Aug 2017
The MM also vents back to the intake tract. Its only when pressure exceeds the check valve on the breather that it vents to atmosphere. With the road course top their is no breather on top, just a hose that comes off that position which can be routed to a location of your choosing. Just for clarification
05-02-2022, 03:20 PM | #78 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
05-02-2022, 03:32 PM | #79 |
+1 I get a close to an oz every 3-4k miles, def more than a tablespoon
05-03-2022, 12:33 PM | #80 | |
Petro-sexual
I don't really like the idea of venting to atmosphere, and the emissions-part of that, but I'm less concerned about that (and what little, if any, impact it honestly might have) than the benefit of relieving crankcase pressure. I'm seeing 15-16-lbs of boost (not making power a lot of you are making at that level with H/C/LTs/etc.), but boost is boost, and pressure is pressure, so I'm kinda' wondering if I might want to jump ship and try a MM. And for clarification - I stated MAYBE 700-miles between oil changes. If I changed at 3K-miles, it would, obviously, be more
05-03-2022, 01:34 PM | #81 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Ps. Just ship it to me and I'll forward it to you
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 Last edited by MartinLe; 05-03-2022 at 01:38 PM. Reason: add info |
05-03-2022, 02:28 PM | #82 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I never had oil residue around it. If you don't like the venting to atmosphere part, you could upgrade to their fitting top conversion. And route that hose to the oem air filter box. I did that before I switched to the wild kit. https://youtu.be/2hdm8i2Huck
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
05-03-2022, 02:45 PM | #83 |
Petro-sexual
AH!!! Sweet!!! Thanks for the info!
05-03-2022, 05:50 PM | #84 |
I’ve been running my MM Wild for 2 years with many dyno pulls and drag strips runs. I’ve never had any oil residue in my engine bay at all. It’s spotless.
Tags |
catch can, elite engineering catch can, mightymouse |
