TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Rockies / Midwest
Old 11-08-2015, 07:15 PM   #71
HRD_WRK
HARD WORKING PATRIOT
HRD_WRK's Avatar
Drives: 2011 CAMARO 2SS RS-AUTO
Some concerns.....
I would recommend you post your initial build in the supercharged section.
I would recommend you upgrade your fuel pump. The stock one with a BAP will most likely not support your goals.
while you do the cradle bushings (do the poly -you dont need solid), replace the pump with minimum of a ZL1 pump and adm controller. You wont need the BAP unless running over 600-650 rwhp. The pump is cheap and easy swap. No E85.
The norm is just to go to a dual pump around 625.
Even if you dont race all out, the launch with your mods and Manual tranny will be enough to break an axle for sure and will wear out the differential. You need 1000hp axles by DSS (Level 4) or GForce. You can upgrade your Diff to a Eaton TT rated to 800rwhp or find a used ZL1 rear. If you dont run drag radials and allow more spin/slip, you may get by without breaking-just dont run too low tire psi.
while you're down there, retorque your driveshaft bolts.
Keep an eye on the fuel pressure during the tuning.
Good luck.
Tim
Long time avid daily reader -thanks to all for your helpful threads!
Bolt ons, Stock Torq Converter - 11.810 & 116.21
HRD_WRK is offline   Reply With Quote
Old 11-09-2015, 09:53 AM   #72
HRD_WRK
HRD_WRK's Avatar
Glad to advise -would hate to see you run out of fuel on a WOT pull - cheap insurance.
sorry - I do not know weights of those two. You could inquire on the tranny section forum.
Old 11-13-2015, 07:31 PM   #73
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Well I'm kind of in a waiting pattern, I'm waiting for agp to resend me there tune, the one they sent me some how got deleted before I could apply it
Moreair1 is offline   Reply With Quote
Old 11-20-2015, 12:48 PM   #74
Moreair1
Moreair1's Avatar
Sound of the car idling, I do have a slight miss fire I will have to solve and as well as a idle code which should just be a vacuum line
Old 11-20-2015, 03:03 PM   #75
Moreair1
Moreair1's Avatar
Sorry it's not recognizin the format I will post once I figure it out
Old 12-03-2015, 07:53 PM   #76
Moreair1
Moreair1's Avatar
Well installed the bap, got all the wideband and boost controller wires hidden and the front bumper cover back on so now just need to work the bugs out and should be good to go
Old 12-06-2015, 08:10 PM   #77
Moreair1
Moreair1's Avatar
Turbo is completed, and thanks to dreksnots advice the idle is fix, so now I can turn and look at some suspension upgrades
Old 12-26-2015, 06:21 PM   #78
Moreair1
Moreair1's Avatar
Well the next project I'm going try is making a noice deadening box for the oil return pump, this has been the only thing that I haven't really liked, the pump that came with the kit is known to be very reliable so I'm going try to make a box that will keep the pump well ventilated yet at the same time silence it down some.
Old 01-14-2016, 12:57 PM   #79
Moreair1
Moreair1's Avatar
Just an update I haven't got to work on my above issue yet but I have ordered bmr trailing arms and soon to order toe rods as well
Cai intake and a few other mods😎
Old 03-16-2016, 07:12 PM   #80
Moreair1
Moreair1's Avatar
Toe rods are now orderedc when I change the trailing arms and toe rods I will post a picture comparing bmr vs stock
Old 03-26-2016, 05:10 PM   #81
Moreair1
Moreair1's Avatar
Suspension
Bmr vs stock
Old 03-26-2016, 06:03 PM   #82
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Are you doing sub frame bushings? Sway bars?
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 03-26-2016, 08:26 PM   #83
Moreair1
Moreair1's Avatar
I'm just doing the toe rods and trailing arms and the bushing at the end of the arm this time, when I eventually get a zl1 rear end I'll probably do the sub frame bushings
Old 04-15-2016, 12:37 PM   #84
Moreair1
Moreair1's Avatar
Next mods I will be adding is a light kit for the back seating area since in the verts there is no dome light in the middle of the roof and this is more to aid with putting my son in and out during night plus will allow him to see back there at night, the kit I'm going with will be OPT7 Aura Smart-Color LED Strip Interior Lighting Kit, I will also be switching out the interior lights to leds plus switching out the front driving lights out to led lights as well, as far as under the hood I will be relocating the catch can breather to eliminate any oil smell from it in the car and as well as I will be adding dynamat to the oil return pump, then after this I will need to add a drive line loop as well as new tires
