11-08-2013, 08:22 PM | #71 |
Thank you bdsdnfam, it is pretty peculiar that no one has made this discovery before, especially since some of the people on this forum are so knowledgeable on so many different aspects of these cars.
11-08-2013, 08:25 PM | #72 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Said it for years............learn the shift points and you can drive with skip shift invisible. I've never found it an issue on Corvettes or Camaros.
11-08-2013, 09:15 PM | #73 |
Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
11-09-2013, 09:34 AM | #74 |
Sometimes this is not possible to hit those shift points, especially while driving in stop and go traffic, unfortunately.
11-09-2013, 11:48 AM | #75 |
Drives: Camaro 2SS/RS M6 Black and IOM Join Date: Sep 2011
First day that I did this I only had to hit the button once and I was good for the whole trip, but yesterday I had to hit the clear button like 5 or 6 times so now I don't know what's up lol
11-09-2013, 12:24 PM | #76 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Well, after some experimentation with HSA on hills steeper than my driveway, looks like I was full of crap. Doesn't work with HSA. Looks like it might be yaw sensor replacement time.
11-09-2013, 03:57 PM | #77 | |
When you are driving hard, you will never see, here or feel GAGS. Shifting at higher RPMs negates the system. But if you are just driving in traffic you should also not observe CAGS. CAGS is usually observed when you launch and are driving "normal" and shifting below 2,000 RPMs. When you are doing this, simply take the shifter down from 1st to the neutral position. Slide the shift lever to the RIGHT as if you are going to 3rd or 4th gear with a slight pause and then pull back left and down into 2nd. Try it. It works. If you aren't in need of a fast gear change this works like a charm. If you need a quick gear change you are probably launching hard and are above 2,000 RPM. I've learned to drive every car with CAGS in this manner and I rarely get gated.
11-13-2013, 11:36 PM | #78 |
Drives: 2012 2SS M6 Join Date: Nov 2013
If I wanted my transmissions opinion on what gear to shift to, I would have bought an auto. I killed the skip shift... and that makes me happy every day.
11-13-2013, 11:40 PM | #79 | |
Drives: '11 2SS/RS LS3 Join Date: Oct 2013
This. Works great - been doing it on my own since I got the car a month ago. FWIW - Set/Clear button does nothing but make the display go away - in my car at least.... |
11-14-2013, 12:08 PM | #80 | |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
11-16-2013, 07:47 PM | #81 |
Drives: '68 SS396, '02 SLP SS, 2010 2SS/RS Join Date: Nov 2009
11-16-2013, 09:45 PM | #82 |
Is there something I'm missing about the simplicity of installing a $20 plug in between the harness and skip solenoid?
Pushing a button or waiting is not a good solution when you really just want to grab second cause you changed your mind about how hard you want to accelerate now that you're shifting? |
11-19-2013, 03:45 PM | #83 | |
Drives: '13 Dusk Edition 2SS/RS M6 Join Date: Nov 2012
I put on long tubes with no cats now so the light is always on anyway so I reinstalled the eliminator.
11-19-2013, 03:57 PM | #84 |
There's not really any way the skip eliminator can cause a cel unless it's not made properly. No problems with my SLP SSE. Plug and play.
