03-08-2015, 07:54 AM | #71 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
You do get boost at some part throttle positions; but max boost is at WOT.
03-08-2015, 09:56 AM | #72 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
I did this yesterday and took it out to see if a difference was noticed. I felt a noticeable extra push at WOT and used my dash logic which gave me a boost reading of 11 psi and the factory boost gauge went farther than I have seen in the past. I will keep an eye on my #2 IAT going forward just to ensure there's no issue. Also, it seems to be making more part throttle boost as my needle sweeps faster as it responds to the throttle input.
Swift....Silent....Deadly
03-08-2015, 10:16 AM | #73 |
ZL1 Pilot
OperationSupercharger boost pressure is regulated to prevent engine and drive train damage. When the engine is operating under high boost conditions, the engine control module (ECM) limits boost pressure to 83 kPa (12 psi). The ECM disables boost under the following conditions:
Results of Incorrect OperationThe following conditions will result in reduced engine power, especially during a wide open throttle (WOT) operation:
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
03-08-2015, 11:20 AM | #74 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
"Vehicle speeds exceed 256 km/h (159 mph) in second, third or fourth gear for greater than 150 s. "
159mph in SECOND GEAR ????? Mine won't do that. |
03-08-2015, 12:03 PM | #75 | |
Drives: 2021 300 Join Date: Jan 2015
03-08-2015, 02:33 PM | #76 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
The supercharger control logic cannot compensate for a mechanical component that requires periodic adjustment or is out of adjustment. For example, the logic will say I want 100% closed, but mechanically it will be at 97%.
So yeah, thanks for posting the operation logic. Now I know this really does need to be checked for correct adjustment, and I am not relying on the dealer to do that.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
03-08-2015, 04:20 PM | #77 |
Drives: 2015 Challenger SRT Join Date: May 2011
^ with that said, it sounds like nothing negative should happen by adjusting the set screw so the plate is fully closed.
03-08-2015, 10:52 PM | #78 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
I am unable to play the video. Can you send a link to a different format?
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
03-08-2015, 11:25 PM | #79 |
I just used a 3/32", long allen wrench to get at the adjusting screw rather than moving the whole bracket. I removed the supercharger drive belt to make access to the screw easier.
At stock setting mine was a half turn open. I set it to a quarter turn open. That was cold. I will check it hot too.
03-09-2015, 08:56 AM | #80 |
Great thread but keep in mind results will vary widely, all dependent on whether it is out of range or not.
There is a tool that sets the preload on the bypass at a certain rod length then you bolt it on while holding the blade open, done carefully the bypass will be in the perfect location for going fully closed without sticking in cold weather and able to go fully open via limited travel of the rod. The concern I have with this is the same as everyone else, the blade can get stuck in the closed position without any gap. So it does need a minimal gap to prevent sticking closed. I think it is a great Idea to check but I don't necessarily agree with the method of adjustment in the video. The tool is the best method. It will have no affect on the tune or the AFR, unless it was specifically tuned with a large gap then you close that gap. Hope this helps.
www.jannettyracing.com
03-09-2015, 10:03 AM | #81 |
Well said Ted.
03-09-2015, 11:02 AM | #82 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
03-09-2015, 11:20 AM | #83 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2013
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15 FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's New times to come with E85 2016 2SS Auto - Hyper Blue Metallic Roto-Fab CAI |
03-09-2015, 03:37 PM | #84 |
Drives: 2014 ZL1 Join Date: Jan 2015
ordered!!
