07-26-2016, 05:01 PM | #71 |
Drives: Camaro Justice Join Date: Jun 2007
Yes sir it does, even better!. If i could put a stronger rear bar in the staggered setup cars, I would. The limitation is the mounting brackets and hardware won't handle the increased loads.
07-27-2016, 11:57 AM | #72 | |
Drives: 2013 2SS/RS Join Date: Jul 2016
The stronger rear brackets and hardware would seem like a quick and relatively easy design & Fab for your outfit, although the demand for them would be pretty small to produce them for general consumption. With the information I have gathered in my short time on this forum, I have gained a wealth of knowledge regarding my Gen-5 SS. So much so, that I have more and more questions all the time! LOL! I'll email you at JPSS with some of my thoughts. Thanks again! Maxx |
11-04-2016, 07:01 AM | #73 |
HomezSS
Drives: 2014 SS/RS Camaro, 2011 Silverado Join Date: Jul 2014
OK - I am in sway bar upgrade overload! so any options, not as simple as it seems! so much discussion, it is now very clear you don't just "upgrade", there is more to the selection than just ordering from Summit/BMR/Hotchkiss or elsewhere. I have a 2014 SS/RS convertible - no engine mods, catback borla exhaust and I did put a set of FR Style 41's 20x10 275/40/20's all 4 corners (HATE not being able to rotate on a regular basis). Daily driver may thru Nov (Stored for the Colorado winters). no track plans, but lots of nice mountain roads for when I am ready for "hammer time". weight of the car and understeer are noticeable periodically and was thinking about (1) suspension brace (Hotchkiss) and (2) upgrading my sway bars. your thoughts on the need for the Hotchkiss? Don't want to upgrade/lower springs - the damn car is low enough and the wife will take the front spoiler off for me if I do. For what I have described - your thoughts on sway bar upgrades to improve body roll? it looks like upgrading the rear only with a 1LE/ZL1 bar might be good - but its the front that seems weak when I hit corners hard? are your black bars over kill for me? planning my springtime modifications/upgrades - as noted above, JusticePete really seems to know what he is talking about - so your help would be greatly appreciated. Thank you
HOMEZSS
2014 SS/RS, FR Style 41's, 20x10x4, Borla CatBack with Touring Mufflers w/Magnaflow Glasspacks, Cold Air Inductions Intake, Diablo 91 Octane Tune, Firm Shift, AFM off, BMR cradle inserts, trailing arms and toe links, 1LE/ZL1 Rear Sway Bar, Jannetty Custom Tune for mods noted above (noticable change to how the car drives!!), JL Audio XD700/5 amp and 10 inch Sub, Focal PS 165K's, special wiring kit and amp board, and lots of dynamat (Amazon version) - Sounds GREAT, Runs Even Better! Last edited by sehovarter; 07-23-2017 at 07:16 AM. |
11-04-2016, 07:06 AM | #74 |
HomezSS
so - don't post until the coffee kicks in - a couple corrections to previous post. first - "so MANY options" (not "so any options") and tires are 275/40/20's all 4 corners. its early in Golden on this fall Friday morning!!
HOMEZSS
2014 SS/RS, FR Style 41's, 20x10x4, Borla CatBack with Touring Mufflers w/Magnaflow Glasspacks, Cold Air Inductions Intake, Diablo 91 Octane Tune, Firm Shift, AFM off, BMR cradle inserts, trailing arms and toe links, 1LE/ZL1 Rear Sway Bar, Jannetty Custom Tune for mods noted above (noticable change to how the car drives!!), JL Audio XD700/5 amp and 10 inch Sub, Focal PS 165K's, special wiring kit and amp board, and lots of dynamat (Amazon version) - Sounds GREAT, Runs Even Better! |
11-26-2016, 10:06 AM | #75 |
HomezSS
Does anyone know what is stock on a 2014 SS/RS Vert? is it the same as what is listed on page 1 of this post (23mm front/24mm rear)? looking to improve front end understeer - already have bigger tires (20x10/275/45/20's all around) and looking at DSE sways and front end links - will upgrade the rear end links to GM 1LE...... thoughts??
HOMEZSS
01-04-2017, 07:26 PM | #76 |
I just ordered the BMR sway bar for my car and pulled the stock one off.. going for the less weight of the tubular BMR over the stock solid one. Stock weighs 15lbs.. BMR weighs just shy of 12lbs, so 3 lbs shaved off. Not much but it all adds up. Very hard to reduce weight on the fronts of these cars.
Car mods: never enough!
01-21-2017, 09:55 AM | #77 |
Drives: 2013 camaro ss 1le supercharged Join Date: Apr 2016
best for autocross and road courses
whats the best for handling road courses and autox
02-08-2017, 01:54 PM | #78 |
WHICH ONE IS THE BEST FOR AUTOCROSS AND ROAD RACES ?
02-09-2017, 08:58 AM | #79 |
Drives: '14 1LS Join Date: Apr 2014
... you don't gotta scream. JPSS black magic sways Sent from my iPhone using Tapatalk
Patiently waiting for my 2023 SS 1LE |
02-09-2017, 09:22 AM | #80 |
02-09-2017, 04:04 PM | #81 |
Wow really? I'd love that! Yes sir I'll be at fest helping Justin Hilliard work his booth! Plan to run the road course and maybe your camaro cross as well! Sent from my iPhone using Tapatalk
02-09-2017, 08:47 PM | #82 |
02-09-2017, 09:41 PM | #83 | |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-09-2017, 09:43 PM | #84 |
