07-27-2013, 08:24 PM | #71 | |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
07-28-2013, 05:53 PM | #72 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Wonder what the weight difference is?
2010 Camaro 1LT V6 (Sold. I will miss her!) |
07-29-2013, 12:56 PM | #73 | |
As far as the ugliness goes - if I were to do this mod, I might have to resort to putting on the silly engine cover - IF I can find it...
07-29-2013, 05:08 PM | #74 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I compared the LLT manifold vs the LFX upper intake. Iirc the LFX upper portion was about 14-16 lbs lighter. I'll have to double check.
07-29-2013, 06:50 PM | #75 |
That's some big weight savings right there. There is a thread floating around in the V6 section containing various weight savings when going from stock to some other part....just feeling a bit lazy to look right now lol.
07-29-2013, 07:16 PM | #76 | |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
http://www.camaro5.com/forums/showthread.php?t=267027 |
07-29-2013, 09:04 PM | #77 |
Went and weighed the LFX upper and lower portion this time, and the LLT intake again.
LFX upper and lower: 7.5 LLT intake w/ plenum cover: 18.75 Adaptolator (phenolic material): 1.5 |
07-30-2013, 12:38 PM | #78 | |
http://www.camaro5.com/forums/showthread.php?t=309918 |
07-30-2013, 02:01 PM | #79 |
I wonder how one would look hydro coated?
08-03-2013, 08:13 PM | #80 |
Did the dyno thing today... It went ok as far as swapping parts and making runs, but the 2LS not wanting to stay in one gear is really making it hard to pick the info apart and show anything useful... I'm going to have to dig deep to see what's what. Dyno didn't show anything useful running locked in 1st with a load. Ended up having to let it shift 1-2-3 in each run, and because of this, and however this particular dyno reads, it says max power is around 16,000 rpms... The rpms are right until it shifts into 2nd...
It's going to take me a while to pick these run files I got apart. IF I can even get anything useful out of them... This goes for all 3 threads I've got going. (this one, the adaptolator, and the extendolator) I'm pretty sure all of this testing, on this car, on this dyno, is worthless :( |
08-04-2013, 12:03 PM | #81 | |
08-04-2013, 01:31 PM | #82 | |
08-05-2013, 10:51 PM | #83 |
If you're just looking for peak hp numbers, IF what I have here is even believable, then:
LLT manifold on LFX engine: 248.2hp and 166.0tq LFX manifold on LFX engine: 263.4hp and 169.4tq I know the TQ is not even close because of the gear reduction, etc running through 1st, and 2nd gear up until the speed limiter in 3rd, but the HP number does kind of make sense since I picked up just shy of .2 in the 1/4 mile from swapping from the LLT manifold back to the LFX manifold the same day. I'm still trying to decipher any useful info from the testing this weekend if there is even anything that is useful... |
08-06-2013, 07:22 AM | #84 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Wow. 15 hp difference. Is that the ported LFX manifold?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
