Old 04-11-2018, 05:55 PM   #8331
Echorama33
Drives: 2017 2SS 50th anniversary Camaro
Echorama33 is offline   Reply With Quote
Old 04-11-2018, 05:57 PM   #8332
Echorama33
Okay - just got MRR017 gloss black with MPSS4 tires...305 rear and 285 front. Also had Borla s type axle back installed...with carbon tips...very pleased.
Old 04-11-2018, 05:58 PM   #8333
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Looks great man!
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-11-2018, 06:12 PM   #8334
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by misterbill77 View Post
This past weekend, I added the OEM footwell lighting kit as well as the Hot Wheels shift boot and Hot Wheels steering wheel. Pics when I have time.
Next up is the GMPP CAI which has been here awhile, want to wait until the next (free) oil change so they can do the LOF and tune on the same trip. Probably will do those in early June when I get back from Israel since I'm about 1200 mi short of needing the oil changed. Yes, it will probably take me that long to put the miles on since it's not my DD... :-)
When you post your next pics, please post up some pics of your car with a couple different angles. I want to see the stance with the new wheel setup.
Excellent! Love those Borla's. If you did the install, did you measure back further than the recommended length, 7" Some guys are cutting back 8" so the pipes don't poke out.
1hprush is offline   Reply With Quote
Old 04-11-2018, 07:38 PM   #8335
Mrfixxit7
Mrfixxit7's Avatar
Drives: FIFTY 2SS Callaway
Originally Posted by F1FTY View Post
Does anyone in this group have the 6-piston GM Performance upgraded front brakes? I know MrFixxIt has the ZL1 upgrade.
I'm asking because I see the ZL1 upgrade brakes don't fit the 50th wheels and I know that they are slighter different than the 6-piston upgrade to allow for the larger rotor of the ZL1.
I'd really like to keep the 50th wheels for everyday use but have the 6-piston brake upgrade and want to see if it's still possible.... Does anyone know for sure?
Originally Posted by Soleil View Post
👍 ok forget my statement earlier. it will fit as it is a performance upgrade to the 2SS. The 6 Pisten fit in all OEM 20” Wheels.
Extract from Performance catalog page 18
23245471
Brembo® Performance Front Brake Package (Six-Piston Calipers, Camaro LS/LT and SS)
Take the braking capability of your Camaro LS/LT or SS to a higher level with the Chevrolet Performance Brembo® front brake system, featuring six-piston monoblock aluminum calipers with performance brake
pads and two-piece, 14.6-inch x 1.3-inch (370mm x 34mm) vented
and slotted DuralifeTM rotors (cast-iron braking rings with aluminum hats). These performance brakes are for the serious track enthusiast looking for ultimate braking performance while maintaining street drivability – and they’re larger than the factory systems for LS/LT and SS (SS features 13.6-inch rotors/four-piston calipers from the factory). The DuralifeTM rotors feature a hardened surface to reduce corrosion and provide quieter braking with less vibration. This front-brake kit includes low-expansion front brake hoses, all necessary hardware and installation instructions.
Fifty is correct, When I mocked up the ZL1 calipers and the 50th anniversary wheels I am very sure they didn't fit. I am hoping to get the calipers back from being powder coated soon and I will try it again and take pics.
Mrfixxit7 is offline   Reply With Quote
Old 04-11-2018, 08:39 PM   #8336
camaromike77
camaromike77's Avatar
Drives: S O L D
Pretty much ditto here........ Car is going back on the road May 1....... That week it will go in for it's (free) oil change, and install the GMPP CAI (which I received for Christmas... )....... Can't wait!!!!!!!
Club F1FTY
Old 04-11-2018, 10:04 PM   #8337
Kaizer_911
Kaizer_911's Avatar
Nice!
6000 - 07/08/16 | Club F1FTY
Old 04-12-2018, 12:12 AM   #8338
Soleil
Soleil's Avatar
Say what ever you want. the MRR17 are the most beautyful wheels for the Camaro. Now you have to lower him a bit than its perfect.
Soleil
Old 04-12-2018, 03:28 PM   #8339
Echorama33
Hey everyone - so I remote start my car...turn it off via remote then try to start it again via remote...won’t start. One flash of front park lights only...what is going on here? Any ideas?
Old 04-12-2018, 03:36 PM   #8340
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I have the M6, so I don't know, but I would say you can only do it once if you cancel via remote.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-12-2018, 04:32 PM   #8341
Echorama33
Thanks heath...on another note - does GM make a factory turbo we could put on the car like for ZL1?
Old 04-12-2018, 04:37 PM   #8342
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
The ZL1 has a supercharger, I'm not aware of any forced induction add on from GM.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-12-2018, 11:58 PM   #8343
Soleil
Soleil's Avatar
Heath,
congratulation on your 2500 post.
Soleil
Old 04-13-2018, 12:00 AM   #8344
Soleil
Soleil's Avatar
Nop. You have to go through the aftermarket.
Soleil
