03-10-2019, 06:54 PM | #57 | |
I used to be Dragoneye...
04-24-2019, 08:25 PM | #58 | |
Drives: 2018 ZL1 Join Date: Jan 2018
Please post pics of the front if possible. I was going to cal Macs and would like to see how you did this. Also, are you using the 40" wheels straps? Thank you |
04-25-2019, 02:38 PM | #59 |
Drives: BMW M5 Join Date: Jan 2015
Over the tire is secure, but frame mount is the safest during emergency maneuvers. It limits weight shift much more than over the tire. Same reason that race vehicles use firmer engine mounts etc.
Hopefully you never have to swerve with that much weight on a trailer, but something to keep in mind. |
04-26-2019, 01:37 PM | #60 |
Drives: 2018 Camaro SS Join Date: Sep 2009
I just went on a winding 4 hour trip with many curves and I must say it was a very pleasant and uneventful trip. I was using a half ton, 6.2 truck and a 20’ steal, tilt deck trailer. There was no weird swaying with the trailer. No odd shifting with the car’s suspension being free. I pulled over 3 times to check my over the tire straps and the tension loss was very slight the first time and none there after. I’m impressed with this setup. For the first time in my life I didn’t have to crawl under the car to tie it off. Upon getting to the shop I noticed another guy dropping off a C7 Z06 with Mac’s through the tire straps and they rubbed the hell out of the side of his splitter. I was so glad I didn’t go there because I almost chose that path. I mounted my e-track rails 63” on center to match GM’s track measurement and they are dead center of my wheels. I used #14 self tappers on every other hole in the e-track and then pulled every other self tapper out and replaced with a 1/4” bolt with nyloc nut underneath. Washers on both sides. I may change out a few more of the self tappers in time but everything worked well just as I did it
04-26-2019, 02:30 PM | #61 |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
Nicely done! (I too spent quite a bit of time making sure that those tracks would go dead center on the tires). So far I've been extremely happy with this whole setup. But you did a nice clean job there. (I need to find a set of end-caps for my US Cargo tracks)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
04-26-2019, 02:38 PM | #62 | |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
04-26-2019, 02:45 PM | #63 | |
Drives: A few Join Date: Oct 2017
I do want to put a winch on it to make it easier to load the car. Edit: Nevermind just saw that you had a 3182. The wider deck on that would be nice but I liked the additional bracing of the 3110 (more cross beams under the deck).
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
04-27-2019, 04:23 PM | #64 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
Aluma Trailer
Extremely happy with my Aluma Trailer and got a fantastic used price! I may look into the E-Track option but really concerned about rubbing of the tire on the track while towing? All the new ZL1 1LE's where tied down with over the wheel straps. This loaded trailer was at our hotel the morning we came out to head home from just outside Chicago. Lots of money going down the road there!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
04-28-2019, 12:17 PM | #65 |
There are no sharp edges on the E-track and the over the tire straps have rubber blocks that set down in the groves of the tire tread. Once the strap is ratcheted tight, the blocks are clenching the tire in 3 different spots and while the tire is being pulled down tight against the rails. With all 4 wheels pulled tight I can’t see how the tire could move at all.
04-28-2019, 03:08 PM | #66 | ||
Boosted Moderator
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
04-28-2019, 04:18 PM | #67 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Have a 2017 SS 1LE & 2017 Z71 4X4 Coloroado, looking to get aluminium trailer, how does your Colarado do towing? I live in Florida, so really not a hill to speak of...
Thx Tim |
04-29-2019, 10:08 AM | #68 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I've got the same truck! Very interested.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
