01-17-2020, 10:02 PM | #57 |
Drives: '19 Camaro 1LE 2.0 Turbo Join Date: Mar 2019
Thanks for the input! Any advice on alignments or an upgrade to the front or rear bar?
01-19-2020, 09:08 AM | #58 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
Ive never raced a turbo so I cant say what a sway bar would do. I did test a v6 1le a few years ago and helped get it moved to FS. Had my wheels and tires on it at the time and stock bars. It maybe could have used a front one to help the initial turn in bite and roll.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
01-20-2020, 10:40 AM | #59 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
275's tend to be a little cheaper due to the higher volume of that size being sold/used. Also, it allows rotation of the tires. For someone new and only going to local stuff, this might be a good option. |
01-20-2020, 11:48 AM | #60 | |
rotating helps for sure. I didn't think it would be as big of an issue on the 4T with the lighter weight and less wheel spinning torque hah.
#53 F Street
01-21-2020, 10:28 PM | #61 |
Drives: broken Join Date: Aug 2009
I ran a non-1LE turbo nationally for two years and did...okayish in decent weather. Sometimes. Couldn't hold a candle to Mike in his Type R at Nats, but was about a second back from him each day at Spring Nats in 2019.
Anyway... The non-1lE turbo is incredibly well balanced and neutral with a decent, but still very streetable alignment. It's sensitive enough to tire pressure differences F/R that you can go from completely neutral to really loose with a minor pressure change at one end or really tight with a change in the other direction. It's really amazing and so much fun. The last thing I ever thought I wanted was more rear wheel or tire width if the fronts were staying the same. The springs, shocks and bars are different for the turbo 1LE, so maybe the balance winds up the same? I only ever ran 275s (both 18s and 19s) and got 150+ runs per set. For alignment, in front, I was at -2.1ish camber i (over time, I was able to get a few more tenths than when new), 0 toe, and caster was whatever it was (6.9?) being non-adjustable. I played a bit more in the rear with camber and toe, but think wound up happiest at about -1.4 camber and just enough toe in to not be 0. I was pretty disappointed to not see more Camaros out there the past two years, because they're such great autox cars. Solid, super cheap (for new), very fun, incredibly easy on tires. But, people didn't want to buy and run them. Sigh.
clyde
Team WTF?! what are you gonna do? :dunno: |
01-22-2020, 06:07 PM | #62 |
Drives: Pending Join Date: Oct 2018
SCCA has not been kind to pony cars in classing. Currently no Camaro or Mustang is the go-to car for any of the street classes. My region looks just like nationals. Tesla/BMW/Type R's. Maybe that will change some day.
01-22-2020, 06:50 PM | #63 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
The Tesla just got buried something fierce, so I think the SS1LE is a contender in BS. I also think the Gen6 SS still has a shot in FS, and is a monster in ESP. I do agree that DS is spec-TypeR for the moment, but it's street class... so the only constant is change.
01-24-2020, 12:40 PM | #64 |
Yeah, Apexit had hinted there was change coming with Tesla. But they're still running BS around here, so maybe the change is set for next year? Haven't seen anything official.
Only one event, but last nat's the FS BMWs were running BS times. Seems a bit stout for an SS. |
01-24-2020, 06:21 PM | #65 | |
Drives: 2019 ZL1 Join Date: Aug 2018
01-26-2020, 08:30 PM | #66 | |
#53 F Street
03-04-2020, 11:17 AM | #67 |
If I wanted to do a 4T for an inexpensive regional CAM-C, would I want to start with a 1LE or base? Aftermarket suspension, wheels and tires can be added...but not sure about aftermarket shock availability.
Is something comparable to Koni Sport on the market for these cars? Might want to start with a 1LE just because of shocks. Then would need minor if any suspension upgrades and big wheels and tires. I assume 19/11's and 305 stones. Lotta rubber for a 4T, but that's okay. The reason for going 4T would be to have a light, handling car with adequate power instead of a nose-heavy fire breather that has to be thundered around the course. Can't be too bad a concept since the GM Performance guys went that way. |
03-04-2020, 02:37 PM | #68 | |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
03-04-2020, 03:37 PM | #69 |
I'm no ace on CAM rules, but they're pretty wide open. Since all a camber plate does is shift the strut bolts at the top, why not just redrill or slot the shock tower holes? Not legal for a lot of classes, but maybe for CAM?
03-05-2020, 07:24 AM | #70 |
I'm sure it's legal, I'd just rather have something less janky. Also, I believe I can easily switch between street and track camber settings pretty easily with camber plates
