TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 08-10-2015, 08:56 PM   #57
jwhutton52
jwhutton52's Avatar
Drives: 2014 Camaro 2SS / RS Coupe
You guys crack me up. You buy a $40,000 car and add thousands of dollars of extras to it and then have a dispute over whether a FARK is worth it or not. Come on. Grow up!!
jwhutton52 is offline   Reply With Quote
Old 08-10-2015, 10:03 PM   #58
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
It's worth it to some people- but some people don't need plug and play. Throwing out options. The sales pitch for $12 worth of connectors for quite a bit more is heavy on this web site. Some people also take satisfaction in doing it themselves.
It's all about options.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 08-11-2015, 09:35 PM   #59
Hopstar
Drives: 2010 camaro Ss
What is a FARK harness? I have an aftermarket amp driving 2 -12" woofers... I got an adapter to plug into the car wiring then connect to the BA amp... I swapped out the rear deck speakers and the 6.5 door speakers. My problem is the back speakers and door speakers (POLKAUDIO DSI650)only play highs and sound like crap... The center speaker in the dash works fine too... Any ideas what I need to do..... I think the BA amp has a crossover in the amp causing my problem...
Hopstar is offline   Reply With Quote
Old 08-11-2015, 09:45 PM   #60
VTSummit
there is not a crossover in the BA amp- it's full range to front and rear woofers.
Old 08-11-2015, 11:12 PM   #61
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
The Fark harness allows you to plug in a new amp replacing the boston amp no cutting wires just plug into factory harness. it has line outs and rcas. But it looks like its no longer on sub thumps website.
Old 08-12-2015, 07:04 AM   #62
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Everyone keeps calling it the Fark harness...its not. He needs the T harness just to connect a sub amp($69 that could be made for $3). He is not replacing the Boston amp. If he was then that would be the fark harness $129
The fark harness I would suggest for most people its plug and play.
The T harness I would not. You need 2 rca connectors, some wire and 5 t taps. anyone could do that.
Rainbow1616 is offline   Reply With Quote
Old 08-12-2015, 07:51 AM   #63
jwhutton52
jwhutton52's Avatar
The FARK (Factory Amp Replacement Kit) is a kit which includes several adapters. I know because I just purchased one. There's the T harness, speaker adapters for rear speakers in a coupe and a harness to hook your after market amp to factory speaker wiring. They are available again. BTW, the rear speakers in a coupe have separate bass and tweeter wires. The speaker jumpers that come in the kit jumper them together so they become full range. I think they have a built in crossover for the tweeters. I will be getting the full kit later this week.
Old 08-12-2015, 08:17 AM   #64
Rainbow1616
I know that, I was just saying the OP doesn't need the Full kit if he is just adding a sub and a sub amp. All he needs is the T harness sold for 69 but not worth it imo. (and an amp kit)
Old 08-12-2015, 11:44 AM   #65
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
The speaker adapters in the FARK kit take the output from the factory amp to the rear 6x9 speakers, and jumps the tweeter outs of the factory amp to the full range output to the woofer of the 6x9, and adds a capacitor to filter out low frequencies to the tweeter. This eliminates the need for separate aftermarket amp channels for both the woofer and the tweeter.
jeffa is offline   Reply With Quote
Old 08-12-2015, 11:49 AM   #66
jeffa
I believe there is a active crossover for the tweeter in the factory amp for the rear 6x9 speakers.
The factory amp also has audio/eq processing for all speakers.
Old 08-12-2015, 01:22 PM   #67
VTSummit
He was (I thought) talking about the woofers not sounding right.
Old 08-12-2015, 03:15 PM   #68
jwhutton52
jwhutton52's Avatar
The rear speakers in a coupe have separate amp channels for the woofers and tweeters. I got the FARK kit today and it contains a set of speaker adpators for the rears that has a built in crossover capacitors. That way you can just replace the factory BA amp with a high powered one and run all of the factory speakers except the middle up front. Some guys in this forum says it sounds pretty good, especially after you add a sub.
Old 08-12-2015, 07:00 PM   #69
Hopstar
thanks for the replies... I added 2 subs last year, I got the tee connecter from sub thump last year when I got the after market amp to just run the subs. I then changed out the factory BA rear and door speakers and just ran the wires to the speakers but they are only playing highs... so i am just trying to figure out how to fix that.. the center speaker and the tweeters are the only ones that are really playing loudly... the doors and the back deck speakers are just playing highs and not very loud. the 12" subs i tapped off the BA with the T harness are working great... any suggestions would be greatly appreciated.
Old 08-13-2015, 02:36 PM   #70
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
Both the FARK and T-Harness are still available
Snoman is offline   Reply With Quote
