TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 07-20-2013, 01:25 PM   #57
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
im
that looks alot like the same fill i have in mine thats flaking off.
i would rather just take it out than having to check it ever few months.
def dont want it coming loose and going down into the valves
mycamaro2011 is offline   Reply With Quote
Old 07-20-2013, 02:42 PM   #58
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
From the picture it looks like there are a couple of precautions that could have been taken so this specific problem didn't happen, that weren't. MACE said it would never happen again, hopefully it has been taken care of... Wonder how RX deals with this problem? I've never even hear of/seen pictures of an RX ported v6 manifold.
Old 07-20-2013, 02:56 PM   #59
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Here is the thread I started on my PIM.
http://www.camaro5.com/forums/showthread.php?t=282288
rtcat600man is offline   Reply With Quote
Old 07-20-2013, 03:23 PM   #60
KMPrenger
KMPrenger's Avatar
Well I checked my IM. Drained the catch can and pulled the plenum cover while I was at it.
When I first got my IM I'm pretty sure the color of the fill was more like Magnum's when I first got it, but now it is a brown color which I'm guessing is due to the oil.
Look closely at the sides and you can see where it has pulled away very slightly from the walls. I tried pushing and picking at it but it is very solid...that said I'm 100% sure if I picked at it enough I could get some of the edges to snap off which is a bit concerning to me (don't want it going down through the engine).
It will be a pain b/c of the downtime, but like I said before, I may wait until over the winter when the car isn't driven much and send her back to have it re-done.
Side note...catch can had a little oil but not much. Its obvious some oil is still coming through b/c of what I found inside the intake, but it isn't a lot either. Its not coming from the clean side b/c I'm running a Vararam intake and so the clean side tube is just hooked to a breather.
Old 07-20-2013, 03:45 PM   #61
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
I've had my MACE ported intake on since last summer and with just about 6k when I first saw this thread.
I went out immediately and gave a check and the plug looked good with no flaking around the seams and seemed to be rock solid.
Luckily at the time of inspection, I saw no oil residue around the plug.
Seems my CC is doing it's job and like KMP, my Vararam has no inlet from the clean side so no oil getting in that way.
Just a guess, but is oil seeping into the seems causing adhesive failure?
I'll be checking again for sure. Just a thought but if this continues to concern me, I just may pry that bugger out of there for piece of mind.
Is it really needed anyway?
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 07-20-2013, 03:55 PM   #62
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I think it is needed so the air flows smoothly or else you would have turbulence right in that area (atleast I would think could be very wrong.)
Old 07-20-2013, 03:58 PM   #63
KMPrenger
KMPrenger's Avatar
I don't know. I guess with the depression there it could cause some air turbulence, but I'm no expert so I can't say.
Old 07-20-2013, 04:33 PM   #64
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Not trying to be a wise guy but I've done many 1/4 mile runs under very similar conditions with the stock IM and the ported IM and saw no difference in my times. Maybe the car is losing something with age.
Actually my best times were with less performance modifications (sans Ported IM, Isolator, Plenum spacer and Hypertech tune in place of the IPF).
Now I love the MACE ported IM. Very nicely done with great support from Jay.
My car is great on the street with no hesitation and from 0-80 mph I couldn't be more pleased.
In my case though, I would perhaps pull the plug with no worries about the turbulence it may create.
Old 07-20-2013, 06:22 PM   #65
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
I think I'll be pulling my TB off soon to check as well. I've got at least 10K miles on my ported IM. I'm fairly confident that there won't be any oil residue since I saw nothing prior to the catch can install at around 5K miles. I also have a Vararam intake, so there won't be any clean-side oil infiltration. I have an Rx ported IM. I'll look for flaking/lifting of the filler... I'll post up what I find.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 07-20-2013, 07:10 PM   #66
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Old 07-20-2013, 10:17 PM   #67
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I am pretty sure I got the first RX ported intake manifold. I have put over 40K with zero problems but will check the manifold tomorrow out of curiosity.
Edit. Maybe it is possible that if the manifolds are being recycled the oil wasn't completely cleaned leading to a poor adhesion. Maybe this was mentioned earlier and I missed as I have not been very active lately.
OOLIE is offline   Reply With Quote
Old 07-21-2013, 10:21 AM   #68
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I think 67 hit the nail on the head. The oil definitely has the chemical composition to deteriorate adhesives.
I also had oil in my manifold which confused me because when I put it on at the same time I installed an elite can and the manifold was bone dry. I suspect the can does not catch everything. I never drilled that PCV orifice or whatever that was so maybe that messes up the can?
Either way people check this because even though mine stayed in one piece little bits of the filler or glue could have went right into the engine. I'm no expert but that probably could blow an engine fairly easily.
I also really doubt taking it out would do much to hurt performance. Maybe if you were running nitrous or FI but otherwise the difference is probably negligible.
DarkneSS is offline   Reply With Quote
Old 07-21-2013, 01:01 PM   #69
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
The clogged orifice would keep oil from even getting to the can, much less to the manifold. A clogged orifice results in oil seeping out elsewhere.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 07-21-2013, 06:16 PM   #70
DarkneSS
Hmm then the cans don't always work 100%
