09-26-2020, 08:07 PM | #57 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Great thread!!! I stumbled on this thread as I was researching alignments; will be lowering my car with AFE springs in a couple of weeks.
I did purchase the GM bolts in advance (not even seeing this thread) based on reading the GM Lowering Springs Instructions. The instructions clearly state to replace the TTY bolts. What I don't get is the various Camaro youtube videos and the instructions that came with my springs do not mention a word about replacing the bolts. Better safe than sorry... |
10-18-2020, 08:37 AM | #58 |
Drives: Fast Join Date: Jun 2013
Are the instructions in the first post applicable to both the Zl1 non-1LE, and the ZL1 1LE? Are the part numbers for the hardware the same?
I would assume yes to both, but it has been questioned in this thread. |
10-18-2020, 12:11 PM | #59 | |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
The OP applies to all 6th Gens, the same alignment bolts are used between all models (LS, LT, SS, ZL1). |
12-23-2020, 11:11 AM | #60 |
Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
I just called a local dealer and they didn't have any of the rear bolts in stock.
In fact, their data base indicated only one dealer in all of AZ has the 11611276 bolts (R toe) in stock. A few had the 11547215 (R camber) This tells me one of two things, either: 1) most dealers are not replacing the bolts, or 2) they do replace the bolts and parts supply cannot keep up with demand? Hmmm....
12-23-2020, 11:15 AM | #61 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
I'm pretty sure no-one is actually replacing these at every alignment... our local dealer didn't stock them when I checked. I bought a set online, and still haven't used them.
12-23-2020, 11:56 AM | #62 | |
i replaced them once after i got new shocks/struts been aligning my car every 3 or 4 months for last 5 years no problems
12-23-2020, 05:26 PM | #63 |
Drives: Duramax, 2018 Camaro SS 1LE Join Date: Nov 2020
Surprised that ARP or (another after market bolt Co) hasn't made reusable replacement bolts for the OEM ones.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
04-01-2021, 01:40 PM | #64 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
What about the Rear OUTER Toe Link Bolts on the other end of the Adjust Link and opposite from the Rear INNER Toe Link Bolts, they are TTY as well, are they loosened and re-tightened when doing an alignment?
If so does anyone have the part number for them? UPDATE: Even though the Camaro Alignment Install pdf says they are a one time use bolt, none of the part manufacturers have any notes on this part saying it is a one time use TTY bolt like the other known one time use TTY bolts.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-01-2021, 01:41 PM | #65 |
Also the Front Camber Adjusting Bolt Kit is part number 88914258 in case anyone was wondering
Update: Just learned from my alignment shop that these Camber Bolts are only used during the actual adjustment of camber and are not on the car before or after alignment while using/driving the car. Not sure what the point of it being TTY is?!
05-08-2021, 01:11 PM | #66 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Anyone know if something like the BMR adjustable toe rods will fit with our FE4 suspension?
I'd like to get a permanent solution to the rear TTY bolt problem. https://www.bmrsuspension.com/?page=...628&superpro=0 It says 2016+ Camaro. No variants are specified. So maybe it fits them all?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-08-2021, 07:43 PM | #67 | |
Drives: 2021 1SS 1LE [Shock] Join Date: Dec 2020
I admit it, I like Mustangs.
Ex Spec Miata driver. |
