04-27-2017, 12:28 PM | #57 |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
I should get the car back tomorrow, I will def let ya know.
715whp/665tq
04-27-2017, 12:42 PM | #58 | |
Dyno Show Queen LOL
Sounds great! look forward to seeing ya out there!.. friend of mine uses them heard good stuff as well! his name is Aaron Lazo.. with the Zl1 called STOMPU!
04-27-2017, 02:47 PM | #59 |
I swear I've seen that licence plate before LOL. Those guys at Gforce definitely know what they're doing. Top notch people and service. I would totally recommend them anyone that needs advice, or wants to go fast .
715whp/665tq
04-27-2017, 03:28 PM | #60 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
Those numbers are on point! I'm pushing 630 out of a manual at 9.5ish with meth.
Pat yourself on the back, you picked one of those sexy fuel systems :P |
04-27-2017, 04:46 PM | #61 |
Woohoo! Thank goodness for the sexy fuel system
715whp/665tq
04-27-2017, 09:35 PM | #62 |
What I love most about your car is, you made over 600hp on stock fuel. So many people come here with basic knowledge and learn from the post and advice on the site. For some reason a static HP value has been set to fuel limits for these engines and that's not how it works at all. Your car has proven you can't use a blanket statement and it's not black and white. It's not a guarantee that you run out of fuel at 570hp, probable is more like it, but not for sure.... your numbers prove that, and I love that about it
04-27-2017, 09:48 PM | #63 | |
715whp/665tq
04-28-2017, 04:08 AM | #64 |
Dyno Show Queen LOL
Ya.. we saw the same thing on the ls engines. For instance the zl1 pump turbo guys were getting 700 and most PD guys were getting 650 out of a zl1 pump. Basically boils down if your kit moves a lot of air with loweat amount of energy to turn that FI pump. Meth will stretch that number as well. Also depends on the dyno 578 on a mustang for us yet we went to a dyno night and made 611 on dyno meter. One thing is for sure though the procharger kits are lower on the torque side.. It would stand to reason that the car that made the most torque with both cars having no traction issues should win everytime if the old saying is torque is what moves the car..and hp is for topend.
04-28-2017, 07:28 AM | #65 | |
You should also be aware fuel pressure on the dyno can be fine for 6 seconds, but then when you go to the track it is a different story. Log your fuel pressure, high low and injector pulse width on the track or on the street the way you intend to use that power. I Hate to see anyone lose a motor. We also would like to know what AFR you are running at WOT didn't see it on any of the sheets or discussion. Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 04-28-2017 at 08:31 AM. |
04-28-2017, 07:46 AM | #66 |
Drives: 2016 2SS Camaro Join Date: Apr 2014
i'm making close to 720 on stock fuel system on 14-16 lbs, just dumping a lot of meth afr at wot is low 12's
04-28-2017, 08:41 AM | #67 | |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
Can you make 600+ YEP on just the stock fuel set up Will it live a long road hard put a way wet life NOPE Guys don't get hung up on a damn dyno numbers, look at the logs and make sure things are in check... then brag about who's dick is bigger |
04-28-2017, 03:48 PM | #68 | |
715whp/665tq
04-28-2017, 03:50 PM | #69 | |
715whp/665tq
04-28-2017, 03:51 PM | #70 | |
715whp/665tq
